08-06-2010, 09:35 AM
How to retrieve 700GB worth of Data
Friends I am in a dilemma to update the firmware of my Iomega HD Screenplay Director. The company website says very clearly that updating the firmware may cause the loss of data. Now since the data is around 700GB on the media player its a challenging task for me to back up somewhere and then again copy those files back after the update. I am sure that its the Table of Content or the File Index which gets deleted with the data intact in the player, when firmware is updated. But the problem is I dont know how to take a backup of this Index(or Table of Content) and later restore this index once I update the firmware.
Any suggesions...... not updating as of now and waiting for the solution.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
08-06-2010, 10:40 AM
Uhu, Not Gonna Happen!
Re: How to retrieve 700GB worth of Data
you thinking is very logical, but i do not think there exist such way to preserve the data.
My personal blog - http://gagan.scholarguru.com
08-06-2010, 11:06 AM
Democracy is a myth
Is it very necessary to update ur firmware?
Just imagine, u found a full-proof way to backup the indexes, and in time of recovery they just did not work.Wat happens then.
If u love ur data don't even touch d HDD.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
08-06-2010, 12:12 PM
or borrow a HDD from a friend...i would do that...we (my group of friends) have used atleast 2-3 laptops to save data of one system if that system needs formatting.utilize all your resources
08-06-2010, 03:03 PM
@gagan007 and rhitwick
What you are saying is absolutely correct. Its wise to learn from others rather than commiting those mistakes on your own. I am planning to copy those files to my Desktop 1 TB HD first and then do the updating of firmware. Now update the Player and then try to restore the data through a better and efficient method(Which I dont know yet and trying to find out). If the restoration fails by the suggested method then copy the data back from my desktop to player.
My only concern was, there should exist a better and a faster method which will prevent me from
copying from media player to desktop= 2-3 hrs of copying time
restoring form desktop to media player= 2=3 hrs of copying time again.
overall a lame (but sureshot method of course)
Trying to cut down the 2-3 hrs of restoration time if the index/table of content method suceeds
08-06-2010, 04:37 PM
Democracy is a myth
The data copy speed would depend on the medium and HDD r/w speed.
With only USB 2.0 ur read/write speed would be close to 25/30 MB/Sec.
In ur case 700GB data may take close to 5hrs. (My 450GB data took 4+ hrs to copy at a rate of 19-20MB/Sec)
08-06-2010, 05:08 PM
my one day would be gone........ just in transferring..... I am sure there would be a easier and quicker method. I found one link but not very sure if this will do.
http://www.partimage.org/Partimage-m...artition-table
08-06-2010, 05:42 PM
Democracy is a myth
Originally Posted by hansraj
I say do backup ur data first in ur desktop. Keep the copy process at night and go to sleep  and then try this method.
In other thought, what if the firmware update does a low level format of ur HDD?
08-06-2010, 06:15 PM
good find buddy...but even they are saying that backup your data in case something goes wrong...I second rhitwick....do not play with your precious data buddy...
heeheehee then there won't remain any table...let alone data
