Old 05-06-2010, 03:42 PM   #1 (permalink)
FOCK FEAR drink BANDWIDTH
stevebadshah's Avatar
Default vmware workstation need help
hello digitians
i want to install windows server 2008 and windows xp in vmware virtual machine
i have 1gb ram size and my partition is 45GB.
can anyone help me to install both the OS and help me with complete guide so that i can practice networking.i want 2008 as my server and windows xp as my client
plz tell me which version of vmware i should use.
thanks
FOCK FEAR DRINK BANDWIDTH:)) 3:16
stevebadshah is offline   Reply With Quote
Old 06-06-2010, 11:11 AM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: vmware workstation need help
instead of workstation use vmware server.. its good and even free!..
what base OS r u using..? xp or win 7..? if it is win 7.. then u need to increase ram.
if its xp then no probs..
after installing vmware server just create new vmware image using windows 2008 server ISO image or XP ISO image.
and also running both 2008 and xp vm at one time with 1 GB RAM is not possible..
within few minutes u r computer will be slow..
i recommend at-least 2 GB RAM for this..
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 06-06-2010, 11:26 AM   #3 (permalink)
teh tech saviour!
saurabh_1e's Avatar
win xp will run easily but i doubt server 2008 req are much more than yours
AMD Phenom x6 1055T @3.50ghz || MSI R6850 @925Mhz OC/PE || 2X2 GB RIPJAWS 1333CL8 || CM 460W REAL POWER ||Asus M5A97 EVO || Lancool PC-K62 || Sennheiser HD201+Fiio E5 || Logitech G400+Razer Golathius || Epson TX121 with CISS || Arch Linux ||
saurabh_1e is offline   Reply With Quote
Old 06-06-2010, 12:15 PM   #4 (permalink)
@khmadhu
thanks for reply
i've read abt vmware workstation and now after reading your reply..i've decided to skip 2008 and now i want to use 2003 server and windows xp.
i'm using my dell netbook with pre installed windows xp.
i want to know how to install multiple OS in vmware and practice networking(MCSE).
and do give me the link of vmware server.if possible give me the detailed step by step guide for installing 2003 and xp in vmware and connecting both
i think i can install 2003 and xp coz both takes a ram of 384+128=512mb and its within 1gb range?
thanks..
waiting for reply
Old 06-06-2010, 09:43 PM   #5 (permalink)
khmadhu's Avatar
register and download vmware server
https://www.vmware.com/tryvmware/?p=server20&lp=1
after registering u will get license key. use that key to install vmware server.
installation of os in vm is easy and u can get it easily by googling around..
just make sure u r both vm OS are in bridge mode of networking.. ip will be assigned automatically for both vm's.
Old 06-06-2010, 10:02 PM   #6 (permalink)
Linoob
celldweller1591's Avatar
try creating Vmware team in vmware workstation and install win server 2008 using it. then install vmware guest os winxp and then try networking . it should work. see this link for details..hope that helps
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline   Reply With Quote
Suggest MB + Procy + RAM to run VMWARE krinish Hardware Q&A 7 09-08-2010 03:20 PM
VMware Workstation 7.1 Released celldweller1591 Technology News 13 28-05-2010 09:02 PM
Run Existing Windows Installation on Ubuntu with Vmware Player subratabera Open Source 6 24-08-2008 12:18 AM
VMWare Workstation ACE 6.0 help on Networking cambodia Networking 1 18-03-2008 02:56 PM
Run Existing Windows Installation on Ubuntu with Vmware Player infra_red_dude Open Source 9 26-07-2007 01:04 PM
- by Niilesh
- by Krow
