Old 03-06-2010, 06:43 PM   #1 (permalink)
sky90's Avatar
Unhappy Problem with video player.!!!
I am currently using Win 7 64bit,monitor samsung SyncMaster2233. I usually use MPC for playing movies, but from some days when i play video in MPC is does'nt play smoothly,its video takes about .5 sec pause after each 3-5 sec but audio plays nice.
I tried VLC but in it video is not clear and we can see square boxex of pixels.
Is there a solution???
sky90 is offline   Reply With Quote
Old 03-06-2010, 07:50 PM   #2 (permalink)
Linoob
celldweller1591's Avatar
Default Re: Problem with video player.!!!
Try this :-
Open VLC player, click Settings > Preferences. Expand the “Video menu"
Highlight “Output Modules( by Clicking on it ). Located bottom right of the window, click “Advanced Options".
Under “Video Output Module. Select either one of the following options ( If one fails, try the other )
-DirectX Video Output
-Windows GDI Video Output
See if that works for you!
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline   Reply With Quote
youtube video download problem GeekBoy Internet & WWW 5 03-04-2011 01:01 AM
Best Codec Packs PrinceHeart QnA (read only) 15 19-03-2005 05:53 PM
- by Niilesh
- by Krow
