Old 02-06-2010, 10:55 AM   #1 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Software for logging system temprature!
I am using Dell Studio 17 with Win7. My laptop powers off whenever i play some heavy games... i think its due to the rise in temp! is there a software that logs the temp so that i can check later. also will it give some warning or something when de temp crosses the threshold so that i dont damage my system.
Thanks
ankushkool is offline   Reply With Quote
Old 02-06-2010, 11:03 AM   #2 (permalink)
Linoob
celldweller1591's Avatar
Default Re: Software for logging system temprature!
try Coretemp.
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline   Reply With Quote
Old 02-06-2010, 11:06 PM   #3 (permalink)
ankushkool's Avatar
does it measure de HDD n GPU temp too?
Old 03-06-2010, 02:24 AM   #4 (permalink)
Linoob
i dont really have a GPU so cant tell you but you can test it for that
Ubuntu User # 31222
Linux User # 516252
Old 03-06-2010, 11:38 AM   #5 (permalink)
ankushkool's Avatar
its only 4 core temp!
Old 03-06-2010, 11:52 AM   #6 (permalink)
Thumbs up Re: Software for logging system temprature!
boss the best i am using is http://www.diefer.de/i8kfan/
this one controls the fans on desired temperature criteria
paid is offline   Reply With Quote
Old 03-06-2010, 05:27 PM   #7 (permalink)
ankushkool's Avatar
does it create logs and give alarms???
Old 03-06-2010, 11:19 PM   #8 (permalink)
ankushkool's Avatar
any more suggestions?
Old 04-06-2010, 12:01 AM   #9 (permalink)
Rox
Go to BIOS by Repeating 'F2' when restarting your operating system (might varie, try all fucntion keys if F3 didnt work). Then go to Temperature Control. Lists all temperature data.
Rox is offline   Reply With Quote
Old 04-06-2010, 06:50 AM   #10 (permalink)
AJJU
azzu's Avatar
HWmonitor is wat u need
I love and Live to Design
azzu is offline   Reply With Quote
Old 04-06-2010, 08:45 AM   #11 (permalink)
ankushkool's Avatar
thank you guys... any idea what should be the max temp for ATI Mobility 3650 HD and c2d?
Old 08-06-2010, 09:21 PM   #12 (permalink)
ankushkool's Avatar
de above are not working for me coz my laptop powers off suddenly hence the log are not saved what should i do? any software that keeps logging the temp in realtime on hdd???
Old 10-06-2010, 01:05 PM   #13 (permalink)
CA50's Avatar
Speed fan is another good temperature monitor and logger.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 11-06-2010, 01:49 PM   #14 (permalink)
Never give up!!
jerrin_ss5's Avatar
Speed fan is good as it helps u monitor your graphics card temperature.
Also if temp is the problem try using some ATI utilities which helps you control graphic cards fan speed .Keep it to 100% while playing games.So whenever less intensive parts of the game appears the graphic card cools off !!!
jerrin_ss5 is offline   Reply With Quote
Old 11-06-2010, 08:02 PM   #15 (permalink)
ankushkool's Avatar
thanks all... will try few of de above soft.
@jerrin: what ATI utilities should i download?
Old 12-06-2010, 09:06 PM   #16 (permalink)
Never give up!!
jerrin_ss5's Avatar
well i don't use ATI but i have a ZOTAC s/w named firestorm for controlling graphic cards fan speed
so i assume ur graphic cards manufacturer or ATI might have some similar s/w
Old 12-06-2010, 10:10 PM   #17 (permalink)
rkneo11's Avatar
hmmm... guess i have to start using one too...
A day without laughter is a day wasted.-Charlie Chaplin.
rkneo11 is offline   Reply With Quote
Old 13-06-2010, 09:52 PM   #18 (permalink)
geek........
Gauravs90's Avatar
I'm using ubuntu 10.04
Is there any hardware temperature monitoring software available for ubuntu?
I installed xsensors, but its not working. do recommend me one
Gauravs90 is online now   Reply With Quote
Old 15-06-2010, 07:51 AM   #19 (permalink)
buddy, get your lappy serviced and cleaned asap... the vents are choked and the thermal glue needs replacement...
and u better hope its under warranty... heating problems with high-end s/w like acad, 3Dstudio, Maya and intensive games on high cpu n gpu usage are known to kill laptops due to excess heat...
Toshiba laptops have a heating issue... and once a problem develops, the lappy will keep on turning off regdless of being serviced... make a claim under warranty then.
Huzefa is offline   Reply With Quote
Old 15-06-2010, 08:29 AM   #20 (permalink)
Super Moderator
asingh's Avatar
Not a good way.
Use HWMonitor, or RivaTuner. Post back if you have issues getting correct temperatures.
asingh is offline   Reply With Quote
Old 27-06-2010, 01:03 AM   #21 (permalink)
TooR
alok4best's Avatar
CPUID...freeware which gives detailed info about ur computer.
GPUID...for detailed info specific to ur grafics card..
I think upto 80 degress shud be okay for ur computer..
Anything above this may prove fatal... U might consider getting a laptop cooling pad. A good logitech pad costs around 1500 I guess..
I wish !!
alok4best is offline   Reply With Quote
All laptop related queries here!!! indro Laptops and Netbooks 2579 Yesterday 09:39 PM
System not booting. acewin Hardware Q&A 11 17-03-2010 06:39 PM
Buying New Laptop: ~30K Budget MetalheadGautham Laptops and Netbooks 42 28-12-2009 01:55 AM
BSNL broadband bottleneck surinder Software Q&A 10 22-12-2009 10:30 AM
- by Niilesh
- by Krow
