Hello guys,
I am just making this thread in hope some one might understand my
strange problem!:fluriod-confused4:
Actually about one month ago 8th April to be precise when i started the computer it goes up to the point where it says microsoft windows xp and the bars running below it and then it restarted. Then i used ubuntu live cd to see what happened and found that the windows folder was empty. I re formatted it. A few days later again the same problem happened but this time when I used ubuntu I found all files intact nevertheless i reformatted it and again it happened yesterday and I found all files intact and today after I shut down my computer and just half an hour later I tried to start it, it happened again. I have to reformat it and these activities of formatting takes about 3-4 hours. I even checked the boot.ini files but nothing special there it was all correct. An interesting fact that before I formatted my PC yesterday I had Ubuntu installed on it as Wubi and guess what I was able to boot in ubuntu but not in xp.
I even tried to go in safe mode but nothing helps it simply restarts. Also if I boot with XP cd then it shows my C: drive as unknown partition and does not detects any windows installation to which I could have expected to repair.
My PC configuration :: core2duo 2.2 E4500, Intel D945GCPE motherboard, WD 160 SATA HDD, 1 GB RAM, Samsung Dual layer DVD writer.
OS:: XP Sp2,
AV:: avast free AV.
I have made no hardware change or driver updates and it ran fine for past nearly 3 yr and i have not installed any new software since then nor updated any except the adobe reader, firefox, and the antivirus. Even these ran fine. In list of new software i use Download accelerator plus but it is almost 3 month when i used for the first time and no problem there. Is there any one who could analyse and tell what the problem is.
