24-05-2010, 12:25 PM
hell boy
recovering data from hdd.....help
hi, this is how it happened, last night there was a power failure and my computer was got off directly( without any ups in line) and i couldn't boot into winxp again.
i thought of installing xp again but couldn't find the disc instead i found ubuntu 9.1, i installed it without reading the on-screen instruction and simply clicking next next etc. now it got installed and when i tried mounting the partitions i was shocked to see, there was no partition, ubutu had created an ext partition out of my whole hardisc. now i want to recover the file, most of the files i have a backup but not all.
i have another system with xp on it.
plz guys suggest something.
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
24-05-2010, 01:09 PM
Tech addict
Re: recovering data from hdd.....help
no one?????
24-05-2010, 01:16 PM
try recuva, handy data recovery (free ones)
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
24-05-2010, 02:13 PM
change is constant!!
u could have used live cd feature!..
did u check the partitions.. with this command fdisk -l
i think by default it will use the free space from the disk to install..
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
24-05-2010, 02:59 PM
Tech addict
24-05-2010, 03:04 PM
hell boy
after the installation of ubuntu ony two partitions were left, one was of 230 gb(ext file system and other 2 gb (linux swap) i have 250 gb hardisc.
now using recover my files, it is scanning the disc real slow, lets see what happens.
24-05-2010, 03:15 PM
Democracy is a myth
Your HDD is converted to EXT3 file system now. Even if you plug it in the other XP system I'm not sure if the softwares like Recuva etc. can recognize it and scan it.
Try Acronis Disk Director....not sure if it will help.
And, why do u think they put those literature b4 the buttons, to read right........I hope from now on you will read'em
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
24-05-2010, 03:27 PM
hell boy
yes hdd is converted to ext3 and i converted it to ntfs back using windows disc managment and created a 230 gb partition.
acronis disc director was of no use, i tried it.
btw, i stopped the analysis and tried to recover the found files but it wont do that, i think i should forget about the data and proceed with installation of os.
24-05-2010, 05:45 PM
Linoob
default filesystem of ubuntu 9.10 is ext4 ... isnt it???and you have got two partitions one"/" root and other swap. Should have used live session instead !
But you formatted your hdd. You can recover your files, they may be corrupted but not all of them. A fresh install should be kept as the last option.
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
24-05-2010, 06:35 PM
hell boy
thanks guys for the help u have offered, but now i have opted for fresh installation as recovering process was time consuming.
anyways it was a new experience.
