I m using windows 7 ultimate 64 bit with all updates upto yesterday
my problem is from last 3 to 4 days a new problem has emerged.After using the PC for say 4 to 5 hours ,the pc would freeze .PC frezzing is normal as you all know ,what what makes it very odd is that this thing happened with me for first time since i have installed the OS which is about 8 months back
normally if windows 7 freezzes for any reason it automatically comes back in a few seconds to few minutes ,however this time whwn it freezed ,it actually frezzed
i mean to say here was no activity sign of hard disk ( the red led atopped blinking ) ,Mouse got freezed ,Keyboard showed no response,when i presses CTRL + ALT + DEL ,NOTHING HAPPENED!!!!!!!! .Okay frustated ,i pressed power key (i have set it to shut down pc if pressed) NOTHING HAPPENED !!!!. Bull **** ,i pressed reset key .It reseted
Or if i press say off switch of UPS ,it got switched off .
If i restart the PC ,then message will come that "computer did not shutdown properly blah blah blah....... if this was because of any power faliure blah blah blah ....... ,needlesly i pressed "start PC normally"
No such type of message was like that a recent hard or soft change had caused pc to malfunction
Alo one day i was listening to songs in WMP,and this thing happened and then strange sounf began to come form speaker like baaaaaaaaaaaarrrrrrrrrrrrrrrrrrrr ,ie like say magnetic tape has got stuck somewhere .
Though i would like to add that one day when this happened ,i was using utorrent .However even after freezing ,the modem was showing activity (I use it in ppoeee mode ,the INET led was blinking along with WAN ) .So i can't comment how is t posiible when everything was freezzed .Net was working
i am using Norton 360 v4.0 Trial as security suite
I m afraid of repeated hard shutdown as i have heard this causes damage to internal circuitry due to sudden surge of electricity .Due to a small software problem ( i m hoping it is that only ) ,i m gonna lose my whole hardware. Please help !!!!!!!!!1111
