Old 22-05-2010, 02:02 PM   #1 (permalink)
Default Using 3rd party bootloader
Hey guys
I m going to install linux mint 9 on my external usb hdd along with win 7 ultimate and win xp sp3. Now the grub bootloader works very slowly for me. I have searched for 3rd party bootloaders and found easy bcd & gag bootloader. What do u guys say is the best of the two?
How can I configure them according to my needs?
Please help
Any other suggestions are also welcome.
Thanks in advance.
ARJOT SINGH is offline
Old 22-05-2010, 03:27 PM   #2 (permalink)
Linoob
celldweller1591's Avatar
Default Re: Using 3rd party bootloader
Grub2 Slow ? in what sense are you talking about ? Easy BCD is not bootloader. It is a program that is used to configure and tweak actual bootloaders in case of bootloader conflicts. GAG is a chainloader and it requires a kernel loader to be installed in the superblock of each bootable partition to handle the different filesystems or kernels but it is difficult to install grub in superblock partition. It can be done by "sudo grub-install /dev/sdx" but i cant be sure if it will work. However in easybcd it is easy as chainloader creates a bootloader image of grub on the local drive & boots from there.
However i would recommend you to use Auto-super-grub-disk in case of bootloader failures. Its the best choice. Install it in a PD and boot, it will show you all your installed bootlaoders and then you can choose from there.
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline
How to install 3rd party apps in my N97-Pls guide me mobileman Mobiles and Tablets 0 20-01-2010 01:19 PM
Get Windows 7 for free by hosting a launch party!!! soumya Technology News 1 06-09-2009 06:02 PM
Techniques to Hide One's Identity on Internet _mAkA_ Tutorials 12 17-08-2007 01:50 PM
CAN I INSTALL 3RD PARTY GAMES N SOFTWARES IN THE LG P 7200?? evil_maverick Mobiles and Tablets 4 07-03-2006 10:36 AM
- by gohan89
