Old 15-05-2010, 08:32 PM   #1 (permalink)
Default having problem in watching 1080 HD vidoes
i have pentium 4 with 2.26 ghz and 1.25 gb ram.. but i am unable to play videos of high quality . when i try to play the sound is fine but the video plays slow. Is there any media software from which i can play those videos . I have tried media player codes, power dvd latest but no success. I will be thankful if any one could guide me.
ravi23 is offline   Reply With Quote
Old 15-05-2010, 11:03 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Default Re: having problem in watching 1080 HD vidoes
Use KMPlayer its best playing HD content, then again, not having a dedicated GFX card may be another reason for ur problem.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline   Reply With Quote
Old 16-05-2010, 04:07 AM   #3 (permalink)
Linoob
celldweller1591's Avatar
try latest version of VLC media player .works good for even blu-ray
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline   Reply With Quote
Old 23-05-2010, 05:39 PM   #4 (permalink)
Blogger
hariharakumar's Avatar
Download DivX player if the files are of .MKV
Visit my blog at http://geekspage.tk/
Check my blog for updates on Blogging, Social Media, Software.
follow me on Twitter: http://www.twitter.com/hariharakumar
hariharakumar is offline   Reply With Quote
Old 23-05-2010, 06:04 PM   #5 (permalink)
Democracy is a myth
rhitwick's Avatar
Cool Re: having problem in watching 1080 HD vidoes
Not required. The Kmplayer does that smoothly and may be better than any other players.
Old 24-05-2010, 01:28 AM   #6 (permalink)
geek........
Gauravs90's Avatar
You can't
you can't even play 720p videos on p4 forget 1080p videos without dedicated gfx.
No player can help you.
Gauravs90 is offline   Reply With Quote
Old 02-06-2010, 10:01 AM   #7 (permalink)
Thanx all for the suggestions . I want to ask celldweller1591 that with my configuration can i play HD videos without graphics card installed from latest vlcx or KM player????. I tried to play in HP laptop but it didnt played. BUt in core 2 duo pc it played easily. Last question is which is the minimum graphic card needed for me so that i can play those HD videos.
Old 02-06-2010, 10:28 AM   #8 (permalink)
Its Best only if its open
ankushkool's Avatar
just get a entry level graphics card (around 2k) and u r good to go
ankushkool is offline   Reply With Quote
Old 02-06-2010, 03:32 PM   #9 (permalink)
Fullbring
Zangetsu's Avatar
Originally Posted by Gauravs90 View Post
You can't
yes dats true....
But i played 720p videos....on my older p4 machine.....with builtin IGP....
though i it played 1080p videos with poorest fps...
@rhitwick: so u use kmplayer....media player classic is good & also vlc...
but for GPU processing use splashit player.....
Old 02-06-2010, 11:11 PM   #10 (permalink)
ankushkool's Avatar
whats that? does it support most formats... can u give a download link.
thanks
Old 03-06-2010, 09:29 AM   #11 (permalink)
Fullbring
Zangetsu's Avatar
thanks
yup here is the link http://www.mirillis.com/splash.html
its the best looking player...& supports hardware acceleartion
Problem in Copy/cut paste bhavik Software Q&A 2 15-05-2010 10:52 AM
Display problem - corruption, lines, video blinking g_goyal2000 Hardware Q&A 5 05-04-2010 05:40 AM
Problem viewing usage abhijangda Chit-Chat 4 04-04-2010 01:08 AM
Problem with new rig:(...plz help official Hardware Q&A 22 15-03-2010 10:31 PM
problem reading digit dl dvds agpraneet Hardware Q&A 0 17-02-2010 05:27 PM
- by gohan89
