Old 13-05-2010, 08:41 PM   #1 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Need Booting from USB
please provide a tutorial how to boot and install XP or win 7 from USB
arpanmukherjee1 is offline
Old 13-05-2010, 09:04 PM   #2 (permalink)
CA50's Avatar
Default Re: Need Booting from USB
its too easy, you don`t have to go through any tutorials. just download a tool called UnetBootin and make any usb drive bootable using any bootable image file.
Download link
http://www.softpedia.com/get/System/...etbootin.shtml
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 13-05-2010, 09:54 PM   #3 (permalink)
Linoob
celldweller1591's Avatar
Try 'wintoflash' to make windows usb bootable. see tut here
i have never used unetbootin beyond making linux bootables
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline
Old 13-05-2010, 10:22 PM   #4 (permalink)
CA50's Avatar
I suggest unetbootin coz that is for anytype of image file(both windows and linux).
For windows seven there is a special tool for making bootable flash drive from windows 7 bootable image. Windows 7 USB/DVD tool
| Nokia 2700c |
CA50 is offline
Old 15-05-2010, 11:56 AM   #5 (permalink)
cooldip10's Avatar
I tried to use unetbootin.. But it did not work out. I also made my pen drive 'active' for booting (using diskpart utility in command prompt).
I use the USB start up disk creator for Linux which is available in any version of Linux.
Everything is Possible
cooldip10 is offline
Old 15-05-2010, 09:38 PM   #6 (permalink)
XLr8
used wintoflash
how to integrsate hdd drivers using nlite ??
SuperSpeed USB 3.0 - Whazzup Mate!!! Deblopper Hardware Q&A 1 26-03-2010 05:56 PM
I/O error while copying some data on to external HDD gary4gar Open Source 4 02-11-2007 12:31 PM
Best Practices For USB Device Users sabret00the Tutorials 1 26-12-2006 11:09 PM
- by gohan89
