Old 12-05-2010, 01:55 AM   #1 (permalink)
Exclamation how to make USB accesible on a port blocked system
hi,
i wand use a usb but the port is showing blocked.
in the device manager a question mark is tagged in front of it.
kindly assist on this
thanx in advance..!!
regards,
tasz..!!
Tasz is offline
Old 12-05-2010, 11:43 AM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: how to make USB accesible on a port blocked system
check u r bios settings, enable usb if disabled..
and check again..
which os r u using..?
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline
Old 12-05-2010, 03:03 PM   #3 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
I am assuming you work for an IT company (most of which are ISO27001 certified for data security). Actually it is not controlled through BIOS but registry. I tried to find a possible solution on the internet but did not get any. So one time I sneaked into my own system when tech support person was connecting portable HDD to my system for installing some s/w...The traces I found there lead me to this:
http://technofriends.in/2008/02/11/how-to-disable-and-re-enable-usb-storage-devices/
or
http://support.microsoft.com/kb/823732
Or as it was posted in TDF too, please have a look here:
Disable Access to USB Mass Storage Drive
My personal blog - http://gagan.scholarguru.com
gagan007 is offline
Old 12-05-2010, 07:51 PM   #4 (permalink)
thnx a lot khmadhu..
gagan007 u got it.. i even tried to run a regedit file but to no avail...
there are several other methods in the link u suggested..
let me try those n i'll confirm which one has worked (hopefully)
thnx again..!!
---------- Post added at 07:51 PM ---------- Previous post was at 07:46 PM ----------
one more issue - wid mu home pc..
i installed original xp sp1 from a cd and then i installed essential softwares and upgraded it to sp2..
then i installed norton 360... n it all began from here..
computer is running as slow as a snail... freezing most of the times..
i tried removing norton.. i tried system restore...
but all in vain..
even the msconfig window sparks n flashes off in a jiffy..
no folder options to view hidden files..
plz suggest if i need to reformat the drive and reinstall all s/w
dis seems to be horrible to me as it took nearly 5 hrs to install all the s/w earlier..
thnx in advance..!!
Tasz is offline
Old 13-05-2010, 12:45 AM   #5 (permalink)
RPG FTW!!!
Techn0crat's Avatar
what is your configuration?Perhaps norton is taxing your system too much.
The truth is out there...anybody got the URL?
Techn0crat is offline
Old 13-05-2010, 05:40 AM   #6 (permalink)
Om Ma Ni Pä Me Hum
phuchungbhutia's Avatar
Maybe there is still some traces of norton left . Use some good uninstaller like free revo uninstall . There used to be norton uninstall software too.
You cant see the folder options then it could be worm or virus that changed the registry.
There is a small program called reanimator if i m not mistaken, to restore registry n clean virus, try it
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
phuchungbhutia is offline
Old 13-05-2010, 06:12 PM   #7 (permalink)
CA50's Avatar
if there is a question mark in front of usb in device manager, it doesn`t mean that the usb port is blocked. Double click on the usb icon and check the device status. If it says like
The drivers for this device are not installed. (Code 28)
To reinstall the drivers for this device, click Reinstall Driver.
then you might have to install the usb drivers.
Can you give a screen shot of you DM.
If you usb is blocked then a registry hack can solve it. Alternatively you can change settings related to usb through a third party software called windows xp manager.
[]d
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 21-05-2010, 02:16 AM   #8 (permalink)
thnx for d reply..!!
i m using hcl beanstalk from last 8 yrs.. (P-IV 2 GHz; 1 GB Ram; 40 GB hard drive)
last year my computer crashed to death so I had to replace the motherboard which one of my friend suggested for mercurry..
n my ordeal started from that day.. i had to reformat the drive several times and reinstall the OS..
then at last I decided to go to Nehru place and buy something really compatible with dis.. I bought ASUS 2 months back... All was well but as soon as I came home installed original XP.. this issue instigated with a new one - computer shuts down without any warning as soon as I attach USB (pen drive or MTS internet card)
Then I asked vendor to change the board but the computer ran well for 3 hrs in his shop..
I again came home and tried.. Alas..! same issue..
plz suggest me if I can updrade my computer at a minimal cost coz I've new ASUS board for P IV 2 GHz processor.. new optical drives from LG.. 1 GB Ram and 2 sata hard drives 80 GB each..
I already have spent enough on thic computer.. i would have bought a new one instead..
but I want to upgrade this one coz wat i would do of this computer then...
Tasz is offline
The Pc Ultimate Doctor:Tune Up Utility 2007 Dark Star Tutorials 6 07-06-2007 12:07 PM
SimCity 4 crashes and restarts system!! hearthacker Gamerz 2 28-03-2007 11:02 PM
BIOS updates - How to recover sagargv Tutorials 16 22-03-2006 09:35 AM
help.about blue screens.random messages.no hibernation hippi QnA (read only) 7 05-01-2006 07:52 PM
Boot INI Option Reference go4inet Software Q&A 5 18-10-2004 12:07 AM
- by gohan89
