Originally Posted by celldweller1591
syntpenh.exe is a process installed alongside the Synaptics touchpad for laptop computer touchpads. Provides additional configurations and support, and is essential on some machines for the functioning of this input device. This program is a non-essential system process. Reinstall your touchpad drivers and see if it stops. Otherwise run a full registry scan via Registry mechanic and see it fixes any errors.
Originally Posted by ramprasad
Probably ur syntpenh.exe or its related files are corrupted..
Uninstall it from Device drivers and re-install it again...
If this driver is not present, u can still use the mouse area in ur laptop, but special features like horizontal/vertical scrolling will not be possible.
Thankyou both for your comments.
However I've done two things and the problem disappeared:
1. I ran SPYBOT and Norton antivirus. It removed some tracking cookies. The message has stopped coming, so, I presume the problem was because of some virus.
2. I also installed Uniblue Registry Booster. On scanning I found some 270 errors. Which I have not yet FIXED. Please comment on this if it is safe to do it and will not give any problem in operations.
Thanks
