Old 05-05-2010, 02:02 PM   #1 (permalink)
Default Urgent Help Required
Urgent Help Needed
Hi fellow g33kz
I am Mridul Singhai from Jabalpur, India . I own a Western Digital Elements Portable 160gb External Hard Drive in which i have stored some movies, documents ,gamez and music . I am facing a problem with it that in it, a folder name $RECYCLE.BIN (SIZE 28 GB) is present. And in it, subfolders are there called
  1. Recycle Bin - I have emptied it
  2. S-1-5-21-764231608-913101004-2147017980-1000
  3. S-1-5-21-1323441200-1623038442-3344255296-1000
  4. S-1-5-21-1361737346-427967954-432400909-1000
  5. S-1-5-21-1953892344-4245925554-1468773186-1000
  6. and 5 more like that
But i cant open alll those 9 folders called S-1-5- etc.....]
SCREEN SHOT IS http://www.thinkdigit.com/forum/atta...1&d=1273048296
Those folders are consuming my 28gigs of space.........
I m afraid that if i deleted them, will they affect my data
Please help URGENT
My system configs are :
Core 2 Duo 2.33 GHZ
2 GB DDR 2 RAM
ASUS Motherboard
Windows 7
solmri is offline
Old 05-05-2010, 02:49 PM   #2 (permalink)
Default Re: Urgent Help Required
Try this link
Aspire is offline
Old 05-05-2010, 02:51 PM   #3 (permalink)
I am not comfirmed but try a linux live cd and see that what it contains but most probably it contains virus so format it watch out for other members reply
Abhinav
abhinav_sinha is offline
Old 05-05-2010, 07:35 PM   #4 (permalink)
Linoob
celldweller1591's Avatar
Try this :
rd /s /q C:\$Recycle.bin
(type the above in run>cmd)
You can also try 'Revo' to remove these files. Download this, go to the cleaning up section, and down the bottom there should be a button asking you if you want to remove this used space .
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline
Old 06-05-2010, 10:13 AM   #5 (permalink)
ramprasad's Avatar
High probability is that, it is a virus.
Scan those folders specifically using Norton/AVG/Kaspersky.
Remove the infections, if any.
If nothing works out, boot the machine in Safe mode and delete those folders.
DONOT attempt to open any of the files.
Opening might spread teh virus to other parts of ur system.
ramprasad is offline
Old 17-05-2010, 10:39 PM   #6 (permalink)
rkneo11's Avatar
alternatively you can use Unlocker to delete these files...
A day without laughter is a day wasted.-Charlie Chaplin.
rkneo11 is offline
Urgent please suggest (Acer 5740/Dell Inspiron/ Dell Stuido15 )??????? phanisrinivas Hardware Q&A 11 19-04-2010 02:17 PM
2.1 speakers required urgent... metalfan Audio 3 24-03-2010 07:56 PM
is gfx card required 4 photoshop?? The Day Walker! Graphic cards 3 19-03-2010 07:23 PM
urgent help required tracert information required from delhi mtnl user paroh Software Q&A 6 30-08-2009 08:22 PM
Urgent Final Clarifications required before purchase tomorrow sakumar79 Hardware Q&A 7 31-08-2007 08:45 PM
- by gohan89
