04-05-2010, 10:30 AM
Firefox problem
Hi,
I have IE8 and FF3.6 running on a HP laptop with Vista(SP1).
I need to access an ip in the range 172.16.*.*: port/page.php
I can access it in IE8 without any problems.
But, I am not able to access it in FF3.6
Can anyone help me with a solution ?
Regards
Ramprasad
04-05-2010, 10:51 AM
change is constant!!
Re: Firefox problem
what error u r getting..? u need to elaborate u r problem...
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
04-05-2010, 11:35 AM
Living to Succeed
Re: Firefox problem
i believe there need to be some problem with the firewall or antivirus. Can u turn off ur antivirus and check once.
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
04-05-2010, 11:56 AM
Re: Firefox problem
@khmadhu : I just get a "Page canot be displayed" sort of error.
@ajayashish: I have a firewall, but this range of ip is configured as safe ip range.
Thanks for both ur replies....
04-05-2010, 12:33 PM
Living to Succeed
Re: Firefox problem
Can u disable the firewall and Antivirus and check
04-05-2010, 02:15 PM
Re: Firefox problem
and also if u r LAN is using any proxy, then u need to put 172.16.*.* in "no proxy" in Firefox.
edit->preferences->advanced->network->settings->no proxy.
u r not able to browse only local sites..? or all sites..?
04-05-2010, 03:15 PM
Re: Firefox problem
@kmadhu
I will try that
I am not able to access only local sites... www opens fine.
04-05-2010, 04:50 PM
Re: Firefox problem
Something like this is the defect of firefox or your firefox must be a beta version
05-05-2010, 08:51 AM
Re: Firefox problem
Diasbled AV and Firewall...
Still not connecting to 172.16.x.x range.
Any more thoughts....?
05-05-2010, 11:44 AM
Re: Firefox problem
did u try that adding the ip range in no proxy..?
where u r using u r computer in home or office..?
when u press enter after typing in the url, what u see in the status bar(down left) in firefox..(connnecting to. or waiting for.. or looking up...?).
05-05-2010, 04:56 PM
Re: Firefox problem
@kmadhu:
yes
computer is @home
looking up...
06-05-2010, 12:08 AM
Re: Firefox problem
Originally Posted by ramprasad
Hi,
Regards
Ramprasad
Have you checked the compatibility issue ? as my router home page of 172.1.*.* doesn't open correctly in ff though it works well in ie8.
There are still some default manufacture sites that doesn't open in ff correctly. I raised a ticket for this @mozilla !!
06-05-2010, 09:58 AM
Re: Firefox problem
@neerajvohra
same with me here... I cannot open the router page either...
Let me know if you get any reply from them.
06-05-2010, 11:12 AM
Re: Firefox problem
what is that u r trying to access..? is it a website? or any ftp/file server..? or some virtual server..?
when u hit enter with ip in the URL, Firefox will not show looking up.., that's only when u enter a domain name.
may be some plug-ins may be missing.. which is in IE but not in FF.
06-05-2010, 11:50 AM
Re: Firefox problem
its your 24OnlineClient Server path.
anyway you cant access it through FF it requires IE +6 version
there is nothing you can do about this.
Twitter Handle : /TheHumanBot
06-05-2010, 01:29 PM
Re: Firefox problem
@neerajvohra
FF quote " Please ask your service provider to add ff in their compatibility list"
There is nothin we can do..but to keep a window open for 172.x.x.x and browsing through FF
07-05-2010, 08:51 AM
Re: Firefox problem
@neerajvohra:
Thanks a lot for the update.
I will continue to use IE8 to access the 172.* IP range...
07-05-2010, 10:06 AM
Re: Firefox problem
@neerajvohra:
He he..no problem
07-05-2010, 10:11 AM
#19 (permalink)
Living to Succeed
Re: Firefox problem
^^ this is when we feel..... Thank god IE is there
11-05-2010, 12:56 PM
#20 (permalink)
Re: Firefox problem
I have upgraded the firmware of my router to mod one..and the IE problem has been solved...Thank god there are alternatives that helps in rolling out IE.
