Old 03-05-2010, 11:48 AM   #1 (permalink)
Linux Noob
Dangerous Dave's Avatar
Post How to install ubantu 10.04 through pen drive?
Sorry for asking noob question.
My DVD WRITER is not working properly. so i wanted to install ubantu through my pen drive. MY HARD DISK is divided into 3 partition
C:// which is a PRIMARY PARTITION in which Windows is installed
D://which is also a primary partition in which data is kept
E:// WHICH IS LOGICAL PARTITION which is blank
i want to install Ubantu 10.04 in E Drive without formatting c and d drive. So what can i do.and tell me how to create pen drive bootable
Dangerous Dave is offline
Old 03-05-2010, 12:19 PM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: How to install ubantu 10.04 through pen drive?
write the ubuntu iso file to u r pen drive using this software (u r pen drive should have enough space)
http://unetbootin.sourceforge.net
check u r bios to boot from usb, and then boot from usb and select manual partitioning.
while installing don't check format option for c and d drive, and format E drive as ext4 filesystem. that's it.
and lastly its not "ubantu" its "ubuntu"
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline
Old 03-05-2010, 02:05 PM   #3 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Hi welcome to the forums,
I noticed a duplicate post so I removed that. Be sure to check the rules out once when you get time .
Also check this link out for help on Ubuntu installation using a USB Stick. Although it shows it for 9.10 I think it might work for 10.04 so give it a try too if the above doesn't work.
FilledVoid is offline
Old 03-05-2010, 02:59 PM   #4 (permalink)
Linux Noob
@filledvoid
sry i dont no how double post has happed but it has happed
Old 03-05-2010, 04:59 PM   #5 (permalink)
Linux Noob
My friend told me that linux make 2 partitions so what can i do for it!
Old 03-05-2010, 05:13 PM   #6 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
BTW computers dont have a concept of C:, D:, E:
You just divide your hard drive into partition which say Partition 1, Partition 2, Partition 3. Windows labels them C:, D:, E:, etc. In case of *nix systems, the devices are called /dev/sda1, /dev/sda2, /dev/sda3. These devices are mounted as /, /home, /usr, /media/music, /media/games, etc. i.e. you access partitions with a particular "directory" rather than labels like C:, D:, E:
Just a note.
---------- Post added at 05:13 PM ---------- Previous post was at 05:10 PM ----------
Do one thing. Delete a partition in your HD. Delete your E: (copy its files elsewhere). By deleting I mean go to Control Panel->Computer Management->Disk Management and right click and delete partition, whichever partition you want to delete.
Then put Ubuntu CD while booting and choose when asked for partitioning: "Use largest continuous disk space"
On a side note, you dont need to bother with partitioning if you use Wubi i.e. just insert the installation device while running Windows and run the setup.
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline
Old 03-05-2010, 06:07 PM   #7 (permalink)
see its simple,,... use any software which can write a bootsector into a pen drive.....ubuntu linux distributions have one such software called boot disk creater,,,,,,,,ubuntu 10.04 lucid lynx ..... can b downloaded from torrent also ... just takes 1/2 hr.....
D4RK8L1TZ is offline
Old 03-05-2010, 06:11 PM   #8 (permalink)
Linoob
celldweller1591's Avatar
its Universal netboot installer (Unetbootin) btw
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline
Old 03-05-2010, 06:17 PM   #9 (permalink)
use 'unetboot'........ n by the way it's ubuntu not ubantu
Old 03-05-2010, 06:54 PM   #10 (permalink)
Linoob
well ,you can make many partitions while installing linux i.e / , /home , /boot , /var ,swap etc .Its the minimum no. that works well with every system is making only on '/' and a swap however swap is not that necessary but it may help sometimes from system crashes when system is heavily loaded .
Ubuntu User # 31222
Linux User # 516252
How to Install Windows ISO File via USB Gauravs90 Tutorials 3 20-03-2010 12:43 PM
Pen Drive does not show up in Windows XP SP2 the_player Software Q&A 5 16-03-2007 06:22 PM
Partition got Deleted from Hard Disk....... prateek_san Software Q&A 3 21-02-2007 02:11 PM
USB pen drive problems the_player Hardware Q&A 2 02-01-2007 11:32 AM
- by gohan89
