You could give Offline NT Password Recovery a try... There is a boot
floppy and a boot CD image. It has an option to disable syskey, but
doesn't work 100% of the time...
1. open run (windows+R)
2. type syskey
3. Select "Encryption Enable" and then select update
4. select "System generated password"
5. select "store startup key locally"
6. click on OK
lo work done
__________________ | A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
