Old 27-03-2010, 11:54 PM   #1 (permalink)
Default Problems in installing graphics driver.
Ok,i just recentely got mine new config which is (i3+DH55TC+1 GB sapphire 5670 HD+500W coolermater+2 Gb DDR3),i install the sound and display drivers from the cd which come up with mother board,then i decided to join my graphics card,But the problem is when i install its drivers(ATI Catylst) my pc gets off abruptly n starts again,and this process keep happening every time i try to install those drivers.
I checked google for any help but got dissapointed,so what is the problem now,what should i do.
medmonster is offline
Old 28-03-2010, 03:01 AM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Lightbulb Re: Problems in installing graphics driver.
Download the latest Ati Catalyst driver from their website and install. CD/DVD accompanied by motherboards very often contain backdated versions of drivers. It's better to install Windows first and let it check for necessary updates through Windows Update.
debsuvra is offline
Is a swap partition necessary while installing Suse? Arun the Gr8 Open Source 11 16-07-2010 05:43 AM
Suggestion required for processor+mobo and also for graphics card subhajitmaji Graphic cards 6 20-03-2010 07:54 PM
using onboard video after installing graphics card vish786 Graphic cards 8 15-06-2007 06:08 PM
Extensions and Their Definitions Sparsh007 QnA (read only) 3 28-11-2006 07:25 PM
Cool 'n' Quiet driver install problem phreak0ut Open Source 10 07-11-2006 10:38 PM
- by gohan89
- by iinfi
