Old 24-03-2010, 10:03 PM   #1 (permalink)
Exclamation svchost.exe problem
whenever I boot my win XP + sp2 system, svchost.exe process ran by network service keeps on running and take 100% cpu usage.
If I stop the process the system restarts.
how to stop it.
IN HOUSE GEEK!!!!!!!!!!!!!!!!!!!!
chirayu garg is offline
Old 24-03-2010, 11:56 PM   #2 (permalink)
Tech'ing life seriously!!
sude's Avatar
Default Re: svchost.exe problem
Originally Posted by chirayu garg View Post
.......If I stop the process the system restarts.
how to stop it......
this clearly means this is an system process. the main issue is actually with any other program which is using this svchost.
Please paste a HijackThis log here.
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 25-03-2010, 01:23 AM   #3 (permalink)
@ sude
what do you mean by hijack this log.
Old 26-03-2010, 12:00 AM   #4 (permalink)
sude's Avatar
@chirayu..
well Hijackthis is used to Scan your computer to find settings changed by spyware, malware or other unwanted programs. Trend Micro HijackThis generates an in-depth report to enable you to analyze and fix your infected computer.
This report is helpful in tracing any malware running in background.
get this from http://free.antivirus.com/hijackthis/
dont download the BETA one.
Thanks
sude is offline
Old 26-03-2010, 11:19 AM   #5 (permalink)
change is constant!!
khmadhu's Avatar
Thumbs up Re: svchost.exe problem
@chirayu
Try this Microsoft patch/hotfix
download and install in safe mode(recommended).
http://www.microsoft.com/downloads/d...displaylang=en
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline
Old 26-03-2010, 01:55 PM   #6 (permalink)
not a newbie.....
papul1993's Avatar
how to stop it.
The same problem happened to me too. It was caused by malware that infected my computer through pen drive. I formatted and reinstalled XP.
papul1993 is online now
Old 31-03-2010, 04:19 AM   #7 (permalink)
Linoob
celldweller1591's Avatar
The same problem was with me when i install xp sp2.I installed Zonealarm firewall + Avast 4.8 and i work fine. Avast in boot time scan ,detected 2 viruses & eleted them but still i had some prob with my network. When the malware tried to access my network , zonealarm blocked it and i work fine .You can try that.
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline
Problem with linux mint ARJOT SINGH Open Source 10 03-04-2010 08:34 PM
hard disk crash problem anant197 Hardware Q&A 3 17-03-2010 07:57 PM
Creative Speaker Problem, inspire 5.1 5200 mumblehere Hardware Q&A 0 17-03-2010 01:29 PM
forum problem Jaskanwar Singh Hardware Q&A 4 06-03-2010 10:56 PM
Pendrive Problem Vivek.28 Hardware Q&A 6 15-02-2010 02:22 AM
- by gohan89
- by iinfi
