Old 22-03-2010, 06:21 PM   #1 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default 32 bit Softwares on 64 bit os
Hi guys
Can anyone tell me is there any issue when i try to run 32 bit softwares on a 64 bit os ? I have no clue which softwares in particular am i gonna need to use, as they would be provided by the college in a few months. So in general is there any specific way of running 32bit softwares on a 64bit os? Or else i know i can always run a parallel os ( 32bit one) so that i can use all the softwares there and keep my 64bit os for rest of my purposes .
Thanks in advance....
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 22-03-2010, 06:35 PM   #2 (permalink)
The Sorcerer's Avatar
Default Re: 32 bit Softwares on 64 bit os
I am using windows 7 64 bit and before this I used windows vista 64 bit sp2. The 32bit softwares that I use is uTorrent, asus xonar drivers, BOINC, audacity, office, msn, gtalk, yahoo, wifi drivers and firefox. I never had any issue with it nor I needed to disable UAC, disable driver signing or change the compatibility mode. The only "bump" on the road was with peer guardian 2 but got it resolved by running as administrator and this problem was on windows 7 without the service packs.
Other than this, if anyone has any problem, I don't think disabling UAC and/or driver signing will barely be an issue or hassle. I haven't used windows xp 64 bit, but people I know are content with windows xp 64 bit in service pack 2. I believe that 32bit compatibility on 64bit OS is overexaggerated upto a certain extent.
Hardware BBQ
The Sorcerer is offline
Old 22-03-2010, 07:06 PM   #3 (permalink)
I use win 7 . Connecting to 32bit servers from a 64bit os ????? Will that be a problem???
Sony Vaio CW26FG
Old 22-03-2010, 07:08 PM   #4 (permalink)
^^ I am not too sure about that. You asked about runnin 32bit softwares on 64bit OS- hence the reply.
Hardware BBQ
Old 22-03-2010, 11:03 PM   #5 (permalink)
Okie. If we can run 32bit softwares on 64bit os, then i guess shouldnt be unsolvable for most other problems.....
will post later with specific problems ( when i actually face them )
Sony Vaio CW26FG
Old 24-03-2010, 04:51 PM   #6 (permalink)
CA50's Avatar
No issue mate. You can install 32-bit programs on a 64-bit OS
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 25-03-2010, 05:44 PM   #7 (permalink)
asia://india/ka/bangalore
a_to_z123's Avatar
Yeah exactly...!!
32-bit S/W run perfectly on a 64-bit OS.. I've had no problem whatsoever till date on XP, Vista as well as 7!
:) I've got my F, C and K . Now all I need is You !!! :)
a_to_z123 is offline
Offline Ubuntu Package Center CadCrazy Open Source 137 16-02-2009 04:13 PM
Is my PC 64 BIT compatible ayushman9 Hardware Q&A 6 28-01-2008 09:11 AM
32 bit or 64 bit is standard? varunbhide QnA (read only) 1 09-08-2006 01:08 PM
32 bit progs????on 64 bit Win Xp Pro ArZuNeOs Software Q&A 7 30-06-2006 01:05 AM
What 64 Bit users are doing? .. Using 32 Bit or 64 Bit OS? rollcage QnA (read only) 27 09-03-2006 07:21 AM
- by gohan89
- by iinfi
