Old 26-02-2010, 11:19 AM   #1 (permalink)
Default Wi-fi problem
Hey guys,
my config is...
a modem - wifi router - pc.
i am able to use the internet on my pc absolutely fine. but when i use wifi on my laptop or on my phone, iam not able to upload files sometimes, open some websites sometimes....What could be the issue.?
When i face these problems i connect to my neighbours wifi () which works absolutely fine.
Sometimes i see a dns error showing up...while none of these problems seam to appear on my pc...
how do i rectify this...!
pls help.
thanks in advance
manan
magneticme200 is offline
Old 26-02-2010, 12:32 PM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: Wi-fi problem
which router r u using..? u mean when u r connection goes off,u automatically connected to u r neighbor's wifi..?
anyway try to reset u r routers configuration and make sure u don't put same SSID as u r neighbor's. u r laptop may confuse!!.enable WPA2 protection with u r desired key(password).
and be within u r wifi range
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline
Old 26-02-2010, 12:58 PM   #3 (permalink)
my modem is beetle 220bx, my router is netgear WGR 614 v6.....
No...i mean..when im unable to upload photos, videos....and not able to posts in forums, i try to do it with connecting from neighbours ip....and it works,,,
also i already have wpa2 protection on my wifi...
Old 01-03-2010, 11:45 PM   #4 (permalink)
help me guys.!
Old 03-03-2010, 11:24 AM   #5 (permalink)
You may be moving out of range or something?
Think My Username's a bunch of random letters?
A deeper meaning lies within......................
Go Find Out!
Tagagat is offline
internet problem anant197 Tutorials 1 19-02-2010 10:39 AM
problem reading digit dl dvds agpraneet Hardware Q&A 0 17-02-2010 05:27 PM
Problem with Pinnacle PCTV-Stereo puttu Hardware Q&A 4 15-06-2007 05:40 PM
hdd weird problem... i bet nobody has this problem vish786 Hardware Q&A 16 11-06-2007 08:21 PM
BIG BIG hardware problem... Please help... Very Urgent... go4saket QnA (read only) 21 13-01-2006 12:00 AM
- by gforz
