if you have selected quick format mode during windows installation,then you may recover most of your data using recovery softwares like undelete plus.it also depends on how much writing process you have done, after windows installation,on the drive.
but if you did full format,then there is no way to get even a 1kb file back.
Common sense is the sense which is not common in common people
