Re: ISO greater than 9gb
have u tried with Nero..?
Note:if u r file system is NTFS then u should be able to create a file upt to 32GB.
(i hope u r not using FAT32).
whats u r system config..? have enough RAM?.
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
