Old 18-02-2010, 03:35 PM   #1 (permalink)
himadri_sm's Avatar
Default internet disconnects randomly when downloading through torrent..please help
i have a reliance 1 mbps unlimited connection..for torrent downloads i use utorrent 2.0 ..everything was working fine but since the last week or so my internet has been disconnecting randomly..mostly when i am downloading through torrents..i get speeds above from 90kbps- 120kbps for some time but then suddenly the connection will log out..this happens mostly within 1-1 & 1/2 hrs of downoading...my OS is Windows 7..my friend has windows XP & if he downloads using torrent, everything is fine...we share the same connection(connected through a belkin g wireless router)..what could be the problem?is there some special setting i must use for utorrent in windows 7?i am currently using it through default settings.please provide a solution...thank you..
View my Portfolio here-
Pixels and Polygons | On Linkedin | On Facebook
Available for freelance. PM me for details.
MSI 890 GXM G65, Phenom X6 1055T, G.Skill 1600Mhz "Ripjaws" 2x2gb Kit, MSI GTX 470, WD Black 500Gb, NZXT Gamma, Corsair Vx550, Hp 22x DVD-Rw, Benq G2420HD, Logitech Mx-518, Xbox 360 Gamepad for PC
himadri_sm is offline
Old 18-02-2010, 04:24 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Cool Re: internet disconnects randomly when downloading through torrent..please help
In XP, there used to be a problem for "Half open ports"...can be resolved by TCP/IP patch.
But, can't comment on Win7, I'm not sure if it still has that issue.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 18-02-2010, 04:26 PM   #3 (permalink)
p_dude's Avatar
Default Re: internet disconnects randomly when downloading through torrent..please help
having too many open connections set in the utorrent?
in that case the router will overload and the connection will reset
try lowering the number of connections...
p_dude is offline
Old 18-02-2010, 04:41 PM   #4 (permalink)
himadri_sm's Avatar
thank you for replying but can you please elaborate?
Old 18-02-2010, 05:14 PM   #5 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: internet disconnects randomly when downloading through torrent..please help
Windws XP SP2 introduces a few new twists to TCP/IP in order to babysit users and "reduce the threat" of worms spreading fast without control. In one such attempt, the devs seem to have limited the number of possible TCP connection attempts per second to 10 (from unlimited in SP1). This argumentative feature can possibly affect server and P2P programs that need to open many outbound connections at the same time.
Full article with solution for XP only
Try this search query in google, "speed issue in uTorrent for win7" without quotes. Check th results.
I'm unable to open a few sites that comes in search result. So....
Another good site for uTorrent optimization, LINK
Old 18-02-2010, 05:26 PM   #6 (permalink)
himadri_sm's Avatar
thank you..i'll try that...another issue that i am facing is with the loading of web pages..almost no website will load at once in firefox..only sometimes they load at once, but at most times i have to refresh the page multiple times to get the pages to load...in webpages with a lot of images only a few images load completely, others only load partially....i get a lot of "server not found"..."oops!this link is broken" errors...but if i keep on reloading a few times, the pages load...my roommate has windows 7 on his HP dv9222tx laptop & he is not experiencing the problems with loading web pages...i wonder then how i can be having these problems when we share the same internet connection..
Old 18-02-2010, 05:59 PM   #7 (permalink)
Democracy is a myth
rhitwick's Avatar
In first post u told, u have win7 and ur friend has XP, now its ur friend who has win7.
How many room-mates do u have?
The solution depends upon the problem, if ur problem statement is so misguiding...what can we suggest?
Possible reason (for XP only)
1>ur Utorrent is hogging all bandwidth, so page loading will take time.
2>Due to half-open port issue ur internet connection is already disconnected as a result u r not able to view any site
Old 18-02-2010, 08:27 PM   #8 (permalink)
himadri_sm's Avatar
sorry you are confused...actually i have two room mates..one has win 7 ult. like me on an hp dv9222tx laptop & the other has win xp on a desktop...the xp machine has no problems...be it downloading or browsing..as for me i only browse when no one is downloading...so the browsing problem is not related to downloading...anyway...i called up the guys from reliance tech. dept & they said they would come check the antennae....also i read in some forum that a few asus m/b's have internet connectivity issues in win 7...so maybe its my m/b thats causing problems...i am not sure but i am searching for a solution on my own..
EDIT this is a screenshot of the speed guide page in utorrent 2.0..as you can see, it doesn't have india under the bandwidth tab..so when i try to run the tests, i always get an error in this section but my port is forwarded correctly.. should i be concerned about this?-
German Government: Stop Using Internet Explorer gopi_vbboy Technology News 2 22-01-2010 05:32 AM
Make Firefox Look Like Internet Explorer praka123 Tutorials 14 18-11-2008 09:28 PM
Stop users from downloading torrent files navino87 Internet & WWW 2 15-07-2007 01:16 PM
software which automatically disconnects internet funkiguy_me Software Q&A 7 22-10-2004 11:25 AM
Windows XP SP2 release date UPDATED 10th AUG 04 leech Software Q&A 68 17-08-2004 12:11 PM
- by gforz
