Re: Database :Help me out...
Rather than u creating a db and working on it, I suggest you use CD Catalog and add all the CD/DVD contents into it. With this, you can view the contents of the CD/DVD without inserting them in to your drive.
You can also create labels in this software so you can group them as you want. Like games, utilities etc. Personally I use the same and it serves my purpose.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
Reason: Added some more info..
