Old 23-01-2010, 02:01 AM   #1 (permalink)
Sarvesh's Avatar
Exclamation Some files on this volume could not be defragmented.
Since yesterday I am facing a typical problem.
When I De-frag my C: or D: partition I am getting the following error after De-fragmentation is finished.
De-fragmentation is complete for: (C:)
Some files on this volume could not be De-fragmented.
Please check the defragmentation report for the list of these files.
C: is PRIMARY SYSTEM PARTITION.
D: is Logical extended partition.
E: is logical extended partition.
After De-fragmenting MFT - the problem went off. But then after a while it started giving the same problem in C: drive.
Any solution ??
"If you understand, things are just as they are; if you do not understand, things are just as they are."
http://www.sarvesh.co.nr/
http://digitalmusicrecording.blogspot.com/
Sarvesh is offline
Old 24-01-2010, 02:11 PM   #2 (permalink)
Default Re: Some files on this volume could not be defragmented.
Windows Defragmenter gives these kind of problems when the file is too big and there isn't much space available to defragment that file.
Try using TuneUp Utilities Defrag. It is perfect.
ico is offline
Old 24-01-2010, 08:02 PM   #3 (permalink)
Sarvesh's Avatar
Thumbs up Re: Some files on this volume could not be defragmented.
Everybody knows that -
Here the case was different - there was no fragmented files in the report.
Foe your Information I have already mentioned that it was due to MFT - and temporarily was getting solved also.( read original post carefully above)
Anyway I solved it permanently.
Sarvesh is offline
enhance ur w700i wid new acoustic driver, increased sms capacity infra_red_dude Buying Advice 175 01-07-2010 10:30 AM
Discover the possibilities of the /proc directory Cyrus_the_virus Open Source 3 19-02-2008 07:41 PM
Forcing Windows XP's Disk Cleanup to delete all temporary files morpheusv6 Tutorials 1 06-05-2007 08:46 AM
Need help with VCD (.dat) files hemantpl QnA (read only) 18 03-10-2006 06:26 PM
How to get 8 to 15 Kbps speed in P2P softs?can any one tell? parthbarot QnA (read only) 15 06-03-2005 08:47 PM
- by gforz
