Old 22-01-2010, 05:30 AM   #1 (permalink)
www.ggauravr.blogspot.com
Exclamation need help with partitioning
Hi guys,
needed some help on understanding partitioning..I read that a disk can be divided atmost into 4 primary partitions..with one of them if marked as extended..can be further divided into logical partitions.. but consider my disk management table which i ve posted below.it seems to be showing 5 primary partitions..and in vista disk management is there a way to make a partition extended ?? it automatically seems to decide on that .. plz help ..thanks in advance..
gaurav@digit is offline
Old 26-01-2010, 01:59 PM   #2 (permalink)
not a newbie.....
papul1993's Avatar
Default Re: need help with partitioning
you can have as many partitions as you like not just 4 partitions.
papul1993 is offline
Old 26-01-2010, 10:31 PM   #3 (permalink)
Ishan's Avatar
@gaurav Your image is corrupted.
Well.. to make extended partitions.. First of all Shrink your Primary partition as much as you want it to be! That means Seperate out all the space from primary partition.
Create a new partition of this all Unallocated space..
Then Shrink this new Partition...It'll be created as Extended partition with Green Color!
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Partitioning your hard drive in Windows Vista narangz Tutorials 23 07-05-2010 09:32 AM
New HDD and partitioning Shikhar QnA (read only) 6 27-04-2008 01:13 PM
Formatting & partitioning keves2002 Software Q&A 3 17-07-2006 07:33 PM
Partitioning .......... Mr.Cool QnA (read only) 10 07-07-2006 12:57 AM
SATA hard disk partitioning and formatting godblessedson QnA (read only) 5 24-06-2005 09:30 PM
- by gforz
