Old 19-01-2010, 06:54 PM   #1 (permalink)
bajaj151's Avatar
Default Error at Startup...plz help !!
I am getting this error at startup :
Windows\System32\config\system file missing or corrupt" Error at system startup.
I tried the solution given here:http://www.askvg.com/frequently-aske...utions-part-1/
but nothing works for me.
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now
Old 19-01-2010, 07:19 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: Error at Startup...plz help !!
Try repairing the windows installation.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
Old 19-01-2010, 07:28 PM   #3 (permalink)
bajaj151's Avatar
I tried...but same error.
Old 19-01-2010, 07:34 PM   #4 (permalink)
Simply a DIGITian
No no I dont mean from recovery console. I mean automatic repair of the windows installation itself. Did you tried this already???
Old 19-01-2010, 07:38 PM   #5 (permalink)
bajaj151's Avatar
How can I do automatic ???
Old 19-01-2010, 09:18 PM   #6 (permalink)
Simply a DIGITian
Boot from XP cd, wait till it detects installed OS and asks for fresh install or repair. Choose repair from there. But take backup's of data from the OS Partition using Linux Live CD before doing this.
Or if you have repair disc you can do it by booting from XP cd and pressing F2 when asked.
Old 19-01-2010, 10:56 PM   #7 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: Error at Startup...plz help !!
Try sfc command
Go to command prompt and enter this,
sfc /scannow
it scans ur system files and replaces them with correct ones if found any corrupted.
Keep ur OS CD nearby...while doing this.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 19-01-2010, 11:04 PM   #8 (permalink)
Simply a DIGITian
^^+1
But I think he's not able to boot into OS. Ayway if you are able to boot into OS then try what rhitwick said.
Old 20-01-2010, 11:40 AM   #9 (permalink)
bajaj151's Avatar
Thanks for the replies...!!! Prob Solved
Old 20-01-2010, 06:31 PM   #10 (permalink)
Democracy is a myth
rhitwick's Avatar
What did u do to solve it???
Please reply...
Old 21-01-2010, 06:57 AM   #11 (permalink)
bajaj151's Avatar
Please reply...
Using 2 commands in Recovery console :
sfc /scannow
& fixboot...and it works !!
Old 26-01-2010, 04:50 PM   #12 (permalink)
ug2
Don't ask for mah title
Location: In another universe solving the string theory.
When I start my computer (Windows 7) it opens the My Documents window and when i close it a black screen is displayed then i start the task manager end process explorer.exe and then re run it from the file menu then it loads. please help
-Xan-
ug2 is offline
Old 26-01-2010, 10:22 PM   #13 (permalink)
Ishan's Avatar
@ug2 Check the startup entries in msconfig! Disable all the strange entries and reply.
Since when did the problem start? I mean after using/installing some s/w?
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 26-01-2010, 11:28 PM   #14 (permalink)
Simply a DIGITian
Looks like virus
Try what Ishan suggested. If that doesn't solve problem. Scan you PC with any good updated AV. I recommend AVG(FREE) / KIS(PAID).
Try scanning online also if you are on unlimited plan.
Old 01-02-2010, 04:44 PM   #15 (permalink)
ug2
Question Re: Error at Startup...plz help !!
Already done that no good but recently installed Malware Bytes and removed it very good software awesome but i still get some warning messages from avast saying that a virus has been detected in the Windows\Temp\idfe(randomly automatically generated names) when I connect online I have already tried an online scan(ESET).Please help I am cheesed off by dem.
-Xan-
ug2 is offline
Old 06-02-2010, 11:03 PM   #16 (permalink)
Seems that your system has not been completely cleared of virus.
It would be better to have a fresh install of the OS after formatting the C: drive. (Ensure that any personal data present in the drive is backed up before performing a format.) After the fresh installation, install a copy of avast/bitdiffender and run a full scan.
anilmathew06 is offline
Hex editing woes! PLZ HELP! futuristically_ancient QnA (read only) 10 20-11-2008 11:48 AM
anyone who has two bollywoodtorrent id plz help by telling it to me very urgent.plz lalu QnA (read only) 1 21-09-2006 11:46 PM
HOW WindowBlinds 5 Starts Automatically at each startup! Vishal Gupta Software Q&A 4 02-12-2005 03:09 PM
Want to remove few programs that run during start up Aanand QnA (read only) 5 25-10-2005 11:37 PM
Plz complete my Intel PC config.. imjimmy CPU / Motherboards 15 12-07-2005 12:29 AM
- by gforz
