Old 17-01-2010, 10:13 PM   #1 (permalink)
linardni's Avatar
Default explorer.exe terminating....system slow...
My computer (Celeron 2.41 GHz, 256 MB RAM running Win-XP SP2) hangs very often whenever I double click My Documents, My Computer or Back button. On restarting, End Task window appears showing termination of explorer.exe program. I have formatted the PC for removal of virus, if any, but it's all the same. Please help.
linardni is offline
Old 18-01-2010, 11:54 PM   #2 (permalink)
Yalam
Default Re: explorer.exe terminating....system slow...
boot your pc with xp cd
go to recovery console by pressing R
run this command for drive cassuming OS is installed in c: drive)
chkdsk c: /r /p
you can repeat this process
and better if you run this command for all other drives.
Since pc spec is low install only softwares you really need. Uninstall all unnecessary softwares. And as soon as you reinstall OS install an antivirus first and other softwares, drivers then. (don't install more than one antivirus and more than one firewall and install security apps which are light on resource)
You can use taskmanager to see which process is taking up much CPU Usage and Memory, identify the software and uninstall that software, or reinstall to recover corruption, or install the latest version of the software.
Defrag your drives and clean your registry(eg using CCleaner)
Go to RUN, type sysdm.cpl and enter
go to advanced tab
click on settings
Under Visual Effects tab select 'Adjust for best performance'
scroll down and put check for last 3 items(or only second last item if you prefer performance against looks)
click apply and ok
gud luck!
Yavin is offline
system very slow suddenly anni QnA (read only) 1 10-10-2009 09:07 PM
Auto system boot for scheduled download!!!!!!!!!!! phreak0ut Tutorials 13 27-08-2007 06:12 PM
Unleash the Power of Ubuntu 6.06!! JGuru Open Source 72 06-12-2006 10:45 PM
System extremely slow - hijack this log er_gurpreet Software Q&A 1 10-02-2006 01:46 AM
Help! My system is too slow udhaybhavan QnA (read only) 9 15-09-2005 05:44 PM
- by gforz
