Old 05-01-2010, 02:31 PM   #1 (permalink)
zzzzzzzzzz........
garfield_56's Avatar
Exclamation No system restore!!! Weird problem
ITS A LONG POST>>>>>>>PLEASE DO READ TILL END!!!!
I was playing a game on my pc...then i closed it...in boom! all the icons on my desktoop were replaced by the "unknown image"..i dunno what it's called but u must be knowing that icon that windows shows when it does not recognise any file format.
i tried restarting, but it din't come back.
then i right- clicked & opened properties of each icon and selected its original icon (via "change icon" option)....All the icons came back this way except that of "my computer" & "my music"......
Any idea why this haapen?????
I also tried to restore my pc to a previos date, but "system restore" is not working...after restarting, it says "could not restore......as no changes were made"...which is so not true!!
One more thing (lastly......) i saw in my "my documents", there was a folder "my data sources" which i did not create and was recently made(b4 all this hpnd)...it had files like:
"+Connect to New Data Source.odc" and "+NewSQLServerDataConnnection.odc".........Is this any Malware's doing???
The interesting thing is that the other User accounts on my pc are working fine......
PLEASE HELP!!!!!!!!!!!
garfield_56 is offline
Old 06-01-2010, 02:23 AM   #2 (permalink)
mortal kombat
quan chi's Avatar
Default Re: No system restore!!! Weird problem
it can be a malware attack.have you checked your pc with any antivirus.please do that first.
quan chi is offline
Old 06-01-2010, 10:20 AM   #3 (permalink)
TheHumanBot's Avatar
game must be pirated.
most of the cracks comes with malwares or trojans
Twitter Handle : /TheHumanBot
TheHumanBot is offline
Old 06-01-2010, 02:34 PM   #4 (permalink)
zzzzzzzzzz........
Unhappy Re: No system restore!!! Weird problem
The game was freeware...(icytower)...got it in one of digit's cds(old ones...was checking it out of boredom)
Old 06-01-2010, 06:02 PM   #5 (permalink)
Gracias Senor
dreams's Avatar
Since you have closed the game abruptly, windows drive/files would hv been corrupt. Try a system restore on a point much earlier.
What happens when you log on into safe mode?
Do a system scan.
Post the results, wil help further.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 06-01-2010, 11:17 PM   #6 (permalink)
zzzzzzzzzz........
Do a system scan.
I agree with the corrupted files(i feel its the dll ones)
I tried to restore it to a point which i had myself created months ago before installing some (trusted & legally free) programs...but it shows the same error "no changes were made so can't restore"....
I ran chkdsk....
Step 1 was clean..
Step 2 found some registry errors i think but it claimed that it had corrected them..
Step 3 was clean again..
I didn't try safe mode yet because pc is working fine when i log on as another user...it seems whatever went wrong only affected one user account (but i dunno how this is possible!)..
so for now, i created a new account for myself...and am working with it...i tried deleting my old one but that doen't happen....the user account window froze & again i had to close it via end task ((....
Exactly after closing the game that day this is what happnd...
when i had exited the game, on the taskbar, a minimised game window was still visible...i tried to close it but it din't work then, so i had to use "end task"......it did show a warning saying..sumthing like "forcing this program to close might result in some undesirable changes"...(i don't remember the exact words )
By the way..i had this game long ago as well...its a simple one...dunno hw it caused so much trouble...
THANX FOR HELPING..
Old 07-01-2010, 12:27 PM   #7 (permalink)
Gracias Senor
dreams's Avatar
It means ur user profile is corrupted. How did you try to delete the old account? did u try from computer management?
dreams is offline
Old 07-01-2010, 08:02 PM   #8 (permalink)
zzzzzzzzzz........
Arrow Re: No system restore!!! Weird problem
I tried to del it by good old control panel>>User Account option...
I'll try that again...it might not hav worked b'coz of the large amount of data in my docs,music, etc....
Btw, might sound like a dumb question, but how does a User Account get corrupted?? I mean is it possible for one account to go wrong without affecting other ones??
Old 08-01-2010, 07:55 AM   #9 (permalink)
Gracias Senor
dreams's Avatar
Certainly possible. All the working files, system files, setting files will be exclusive saved under the user profile and if anythn goes wrong, either it corrupts the profile or the system files itself.
Juz think, for making a simple mistake in Guest or limited user account, do u want the whole Windows to go corrupted including the default admin account? Thts serious m8.
You can login as admin, retrieve the data from the corrupted profile, I mean my docs, music et all. If u need.
Then you can try deleting the account from computer management.
control panel - admin tools - comp mgmt - expand local users and groups from left pane, click on users - right pane, right click on the user account and delete. This wil work, if ur method fails again.
dreams is offline
Old 08-01-2010, 03:12 PM   #10 (permalink)
zzzzzzzzzz........
Thanx a lot...
And do you have any theories why my system restore isn't working??
Old 09-01-2010, 10:38 AM   #11 (permalink)
Gracias Senor
dreams's Avatar
hmm..gud one. Here u go..try this.
Right click My Computer, choose "Properties" then click on "System Restore" tab.
Put a check in the box for "Turn off Restore on all drives". Click OK, then Reboot your PC.
After you reboot, go back to the System Restore tab and uncheck the box. Click OK.
Next, go to Start/Programs/Accessories/System Tools then click "System Restore". Choose "Create a Restore Point" and give it a name as u like.
For testing purposes, after u created a restore point, try to remove soem unwanted programs and once done, do a system restore and check.
dreams is offline
Weird problem need help dashingdude Hardware Q&A 14 27-10-2007 07:37 PM
Windows Vista Tweaks Ankur Mittal Tutorials 30 09-10-2007 03:27 PM
Auto system boot for scheduled download!!!!!!!!!!! phreak0ut Tutorials 13 27-08-2007 06:12 PM
System Shutdown Problem and Maintainence anna_don QnA (read only) 3 03-05-2005 01:29 PM
- by gforz
