Old 02-01-2010, 09:32 PM   #1 (permalink)
mortal kombat
quan chi's Avatar
Default please help.shutdown menu changed.
hi guys.
well i am having a problem.
by mistake i installed 'microsoft client server' and 'microsoft network sharing' something like that by network connections>lan> right click> properties.
later the 'shut down' of the system changed to this.No 'log out' option.
whenever i used to open my system i would get some network setting message also.
therefore i uninstalled both.
that network policy (something like that) setting option at start up before windows is now gone.
But the shutdown process is still the same.
please help is there any way to make the 'shutdown' option normal(default) like before.
quan chi is offline
Old 02-01-2010, 10:54 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Cool Re: please help.shutdown menu changed.
The last screenshot shows up when u select classic log-on menu.
Were u always used to get such option?
If not, then do this:-
(For start menu fix)
right click on taskbar-->Properties-->StartMenu tab
Here u may find that the "classic stat menu" option is selected, select the other option i.e. "start menu" radio box.
Try this and reply...
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 03-01-2010, 10:55 AM   #3 (permalink)
mortal kombat
quan chi's Avatar
Default Re: please help.shutdown menu changed.
^^thanks for the reply.but that way too i used to get that last box.
i think i figured it out myself.
well it seems the problem is solved.
Go to Start>> Control Panel
Click User Accounts
Click "Change the way users log on or off"
quan chi is offline
Play with Registry Editor kal_21 Tutorials 16 26-12-2007 09:02 PM
Start menu registry hacks to make ur start menu more bautiful and comfortable Siddharth Maheshwari Tutorials 9 22-01-2007 07:01 PM
Customizing Windows XP Home Edition : Just for nOObs Quiz_Master Tutorials 2 21-01-2006 12:19 PM
How to use flashget in opera 8 Gaurav Software Q&A 6 22-10-2005 11:19 PM
Use "Windows" your own way ! rajkumar_personal Software Q&A 6 26-02-2005 11:40 PM
- by gforz
