Old 31-12-2009, 02:10 PM   #1 (permalink)
ug2
Don't ask for mah title
Location: In another universe solving the string theory.
Unhappy Help required to uninstall a game!!!!!!!!!!
I had bought a pirated version of Gears of War (1). After that it deleted it using Shift+Delete method. One day while uninstalling some other software in the control panel I saw Gears of War icon I clicked on it to uninstall it but it showed an error:-“The installation source for this product is not available. Verify that the source exists and that you can access it.C:\Windows\Installer\1849fe2.msi”. Please tell me how to remove the icon and all the game data from my computer permanently.
I don’t want to install the game again due to:
1. The fear of viruses.
2. And the time taken to unpack + install=6 hours.
I am using Windows 7.
-Xan-
ug2 is offline
Old 31-12-2009, 02:23 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Help required to uninstall a game!!!!!!!!!!
Wow so proudly u r saying.....
Use revo uninstaller...or manually delete it then remove its entries from regedit...
Zangetsu is offline
Game Programmer required kalpik Gamerz 4 26-06-2007 08:57 PM
Max Payne - One Helluva Game s18000rpm Gamerz 46 20-01-2007 12:10 PM
The Quest : Game for Fame mobile_freak_2020 Gamerz 2 28-02-2006 08:59 PM
Godfather film director whacks Godfather game Sourabh Gamerz 3 13-04-2005 02:48 PM
"Top Spin" Tennis Game for PC. Anyone has this game? Yoda Gamerz 3 04-04-2005 07:55 PM
- by gforz
