Old 18-12-2009, 07:31 PM   #1 (permalink)
Quick Shooter
phanisrinivas's Avatar
Default master volume control????
In my PC , I cant enable the advanced controls for master volume
- how to disable limited volume in my pc ( i used xp )
- Any fix is there for advanced controls
- I have Jetway 945 MB ( Realtek sound card).
- So thanx in advance..
---------- Post added at 07:31 PM ---------- Previous post was at 06:06 PM ----------
Anyone Help me...
phanisrinivas is offline
Old 18-12-2009, 08:40 PM   #2 (permalink)
CA50's Avatar
Default Re: master volume control????
I hav da same prob, my question is below ur thread
but no reply
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 20-12-2009, 02:54 PM   #3 (permalink)
[A]bu's Avatar
Do you find everything disabled in "Audio" in control panel?
-If yes then, your driver stopped working.
-If no, then try re-installing the audio driver.
or try "sfc /scannow" in "RUN" and insert the "WINXP CD".
Do or Die
http://www.hamrobrt.com/howto-install-flash-player-in-ipad/
[A]bu is offline
Old 20-12-2009, 03:34 PM   #4 (permalink)
CA50's Avatar
It has nothing 2 do with drives. Just da advance option with bass n treble controls are disable. I think a registry tweak will solve da problem.
| Nokia 2700c |
CA50 is offline
Old 20-12-2009, 04:04 PM   #5 (permalink)
Quick Shooter
Please help anyone for this tweak
Old 20-12-2009, 04:29 PM   #6 (permalink)
CA50's Avatar
i also need the solution
| Nokia 2700c |
CA50 is offline
Old 20-12-2009, 11:42 PM   #7 (permalink)
XLr8
arpanmukherjee1's Avatar
hi.
either i am wrong or missing the point...
there my be no tweak.
RLT snd drv does not let windows handle the controls.
in control panel there must be icon for realtek sound management
i have gigabyte ga-945gcm-s2l m/b and use xp SP3. realtek icon shows up in the notification bar and the equalier woks jst fine
arpanmukherjee1 is offline
Glossary of Acronyms for PC and Server Technologies topgear Tutorials 7 29-09-2007 03:58 AM
NO bass option in volume control window!!! bala4digit Software Q&A 11 25-12-2005 12:21 PM
95 Seconds to boot! PROBLEM sudisha Software Q&A 13 18-06-2005 04:56 AM
- by gforz
