Old 16-12-2009, 10:46 PM   #1 (permalink)
CA50's Avatar
Cool Why r these disable [audio problem]??
Hi fnds, got a prob. My pc have got XFX nforce 630i mobo which has got realtek HD audio output. When the check the volume control panel(in XP), there is ab advanced option which has got seperate adjustment for bass and treble. the problem is that those options are disable (check pic below).
Can anyone of you tell me how the enable this, and also if you have got the same problem.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 18-12-2009, 06:05 AM   #2 (permalink)
CA50's Avatar
Default Re: Why r these disable [audio problem]??
Plz help!!!!!!
| Nokia 2700c |
CA50 is offline
Old 20-12-2009, 07:51 PM   #3 (permalink)
XLr8
arpanmukherjee1's Avatar
the control are disabled as they r not meant for windows to configure
goto contol panel-> realtek CP.. a notification icon appears as red speaker. dbl clk it
or type msconfig in srch (vista) :: run (xp) and enable soundman
arpanmukherjee1 is offline
Old 20-12-2009, 09:33 PM   #4 (permalink)
CA50's Avatar
^^ hey what do u mean?? what should i change in the cp
| Nokia 2700c |
CA50 is offline
Old 20-12-2009, 11:04 PM   #5 (permalink)
geek........
Gauravs90's Avatar
Have those treble and bass option worked before?
Gauravs90 is offline
Old 21-12-2009, 11:00 AM   #6 (permalink)
CA50's Avatar
No those options didn`t work before. I was wondering that there might be any tweak to enable those and play with them.
| Nokia 2700c |
CA50 is offline
Old 21-12-2009, 01:31 PM   #7 (permalink)
geek........
Gauravs90's Avatar
If those options never worked before this might be that hardware doesn't support it.
I see in my AC'97 many options that never worked.
So don't care about it.
Old 21-12-2009, 02:57 PM   #8 (permalink)
XLr8
+1
thats exactly what i ment
Old 21-12-2009, 05:29 PM   #9 (permalink)
CA50's Avatar
you may be right, i have got realtek HD audio. Do you have that? HAve you ever faced that problem?
| Nokia 2700c |
CA50 is offline
Old 21-12-2009, 06:26 PM   #10 (permalink)
geek........
Gauravs90's Avatar
I already said i use realtek AC'97
And it dosen't have those options
Old 21-12-2009, 10:00 PM   #11 (permalink)
XLr8
mine too dosent have such option.
the equalise is provided in the realtek
mine looks like diss : gigabyte m/b
<a href='http://www.picscrazy.com/view/RLTGigabyte'><img src='http://www.picscrazy.com/thumb/RLTGigabyte.jpg'></a>
---------- Post added at 10:00 PM ---------- Previous post was at 09:57 PM ----------
MASTER TUTORIAL: Make Your Windows XP Super Fast !!! Vishal Gupta Tutorials 82 28-05-2008 03:16 AM
Services that can be dissabled in WinXPSP2 DukeNukem Tutorials 5 15-10-2006 10:59 AM
Disable uneccessary XP services ! gain resources ! anandk Tutorials 11 30-07-2006 11:18 AM
Close unwanted services ... QwertyManiac Tutorials 3 18-04-2006 02:57 AM
tips on increasing performance of computer iamtulipin QnA (read only) 10 07-03-2005 10:39 PM
- by gforz
