Old 10-12-2009, 12:48 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
User Name's Avatar
Question Autopatcher and XP SP3 is same ?
Is the latest autopatcher and SP3 contains same updates?
Should i just go for updating from Sp2 to Sp3 OR use latest autopatcher?
User Name is offline
Old 10-12-2009, 09:39 PM   #2 (permalink)
User Name's Avatar
Default Re: Autopatcher and XP SP3 is same ?
Old 12-12-2009, 09:06 AM   #3 (permalink)
jal_desai's Avatar
I am sure you know that Autopatcher is a 3rd party package that includes latest security updates whereas SP3 is developed by MS. For better support and seamless integration, go for SP3 only. I suppose you can use Autopatcher on sp3 too in order to install more recent security updates.
TechExplorer.in
jal_desai is offline
Old 12-12-2009, 12:47 PM   #4 (permalink)
Autopatcher allows you to add the updates to your system, but it is not for service packs. Also, SP3 is a collection of updates for your system, but there are many newer updates to be added after SP3 was released.
So, you first need to install SP3 on your system. Then, you can use Autopatcher or the built in Windows Update to download and install the newer updates.
Arun
sakumar79 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/123156-autopatcher-xp-sp3-same.html
update sp3 with recent updates - Google Search This thread Refback 22-01-2011 12:52 AM
AutoPatcher for Windows XP SP 2 (32-bit), February 2007 - Update rajat22 Software Q&A 3 19-02-2007 08:12 AM
AutoPatcher for Windows XP SP 2 - August 2006 - Full, Lite & Update rajat22 Software Q&A 7 17-10-2006 10:24 PM
AutoPatcher September 2006 for Windows XP Service Pack 2 hyde Software Q&A 2 20-09-2006 08:18 AM
AutoPatcher for Windows XP SP 2 (32-bit) - April 2006 - Full rajat22 Software Q&A 12 19-07-2006 09:44 PM
Autopatcher XP Problem raval_manoj Software Q&A 5 01-09-2005 10:37 PM
- by gforz
