Old 18-11-2009, 10:32 PM   #1 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
Default problem with .vcd file
i have winning eleven 9 game in .vcd file. how to install it?
http://www.flickr.com/photos/37859042@N02/4114642591/
IronCruz is offline
Old 18-11-2009, 10:37 PM   #2 (permalink)
clmlbx's Avatar
Default Re: problem with .vcd file
First reattach ur photo properly as it is not viewable and what I remember this is virtual cd file .. You will need that software to use this file. Don't remember actually which software was it but for sure it is virtual cd. most probably this is the software :- http://www.virtualcd-online.com/
clmlbx is offline
Old 18-11-2009, 10:39 PM   #3 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
just see it now...and tell me the procedure...
IronCruz is offline
Old 18-11-2009, 10:43 PM   #4 (permalink)
CA50's Avatar
hi buddy where is the picture??
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 18-11-2009, 10:44 PM   #5 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
click here
IronCruz is offline
Old 22-11-2009, 04:07 AM   #6 (permalink)
thinking di9it'al
di9it's Avatar
Its a virtual cd image file that is been split into volumes named:
WE9.VCD.D00
WE9.VCD.D01
...i dont know into how much volumes.
And these volumes will be joined to make WE9.VCD file that can be mounted in Virtual Drive.
I think u need to get other volumes of the split .VCD file and use joiner program to join them.
Try HJSplit or similar program...
My Rig:
AMD Athlon 5600+ @ 2.9GHz
Gigabyte M61PME-S2 MainBoard
Kingston 1x2GB 800MHz DDRII RAM
GFX Card : ???
HTC Touch Pro
di9it is offline
Please Help Out Guys Official Techie QnA (read only) 2 05-05-2007 02:08 PM
Quake 4 ..starting error.. medigit Gamerz 4 14-04-2007 06:56 PM
SimCity 4 crashes and restarts system!! hearthacker Gamerz 2 28-03-2007 11:02 PM
Help: Problem With Nero DVD Writer.... RoughGuy Hardware Q&A 2 16-09-2006 03:01 PM
Writer problem. nevillle23 QnA (read only) 5 20-07-2005 12:22 PM
- by chris
