12-11-2009, 09:19 AM
Fullbring
32-Bit or 64-Bit ???
Hi all,
I am in a dilemma whether i shud go 4 32-Bit XP or 64-Bit XP ?
coz if i install 64-Bit then all my 32-Bit apps wont run (such as antivirus,ms office & 3rd party apps) & what will happen 2 all my games iso's whether they run on 64-Bit OS....
morever in 32-Bit only 3.5 GB of RAM is utilized whereas in 64-Bit more than 4GB of RAM can be used....
12-11-2009, 10:00 AM
Bond, Desi Bond!
Re: 32-Bit or 64-Bit ???
most of the 32 bit apps run on 64bit OS. but its better to go for 64bit win7.
12-11-2009, 10:12 AM
If you want use PHotoshop then You must go for XP 64 Bit.
Rest Its good for multitasking also as it can utilize more ram.
And almost all the 32bit applications (which you mention those also) works equally well in xp 64 bit.
So go for 64 bit. I too using that.
12-11-2009, 11:03 AM
Super Moderator
Originally Posted by KaranTh85
Hi all,
1. If RAM >= 4 GB : 64 BIT OS
2. If RAM < 4GB : 32 BIT OS
All 32BIT applications run seamlessly on the 64BIT OS, via WoW (windows on windows) subsystem. All the M$ 64BIT OS's have WoW.
Only constraint is, your processor should support 64BIT instructions. I am using XP 64BIT, past 8-9 months...absolutely no issues. Only problem I faced was that I could not find drivers for Sony Cybershot.
12-11-2009, 12:00 PM
Crowman
@ OP Give your config on which you want to use the OS. It will help us guide you better.
12-11-2009, 12:25 PM
If you have 4GB RAM then why not 64 bit. Its a default choice.
12-11-2009, 02:35 PM
Make Way the LORD is Here
use 64 bit... its now mature enough
12-11-2009, 05:41 PM
Yes 64 Bit is the nice one.
12-11-2009, 06:37 PM
64bit is matured now..
BUT
i don't think going for 64bit XP is a good idea now!
better get a Windows 7 64bit...
12-11-2009, 09:42 PM
may be keep both type of os easy ine
13-11-2009, 05:59 AM
Are you going to buy the Original one. I don't think so.
If Original then Install xp 64 bt.
If Not Original then you can Install Both whats the problem.
13-11-2009, 09:14 AM
Fullbring
 ohh...then drivers might become a problem here for 64-Bit OS.
thank u all guys dat means there is no need 2 download all the 64-Bit versions of software i have....
and now the prices of HD4850 r slashed heavily so shud i go 4 them or wait 4 HD5XXX
series 2 come down in price ?
the only card b-low rs 10k mark is HD5750 is it better than HD4870 in performance ?if yes then how much?
moreover is it good 2 go for a DDR5 card than DDR3 such as HD4850 DDR5?
I will soon post my required config...
13-11-2009, 10:23 AM
Buy the HD4850 card as it is cheaper and can run almost all the games easily in high settings except ( Crysis and Clear sky).
13-11-2009, 12:41 PM
Crowman
Better W7 x64 than XP x64. For a GPU, well, I'd ask you to wait, but if you can't then get the 4850. What price are you getting it for?
13-11-2009, 02:06 PM
Fullbring
ya I know windows 7 is good when compared with older oses....:-P
Well i will update on Feb or March.....
my budget for a graphics card is 10k not more than that...
& my selected proccy is C2D E8400
RAM is not selected (confused between DDR2 or DDR3)
mobo will be from Gigabyte(  coz i rely on dat my old 5yrs mobo is still gud )
Posted again:
y not the HD4870 DDR5 it is available under 10k....
also what performance,graphics improvement will DX11 has...i dnt knw????
Reason: Automerged Doublepost
13-11-2009, 09:06 PM
Crowman
Posted again:
So Mr. Karan is buying a new rig. Well, honestly, C2D E8400 is a bad choice, especially so now. If you list your budget for rig alongwith your primary usage, then we can help you best.
Anyway, assuming that you looking for best graphic card under 10k, then Zotac GTX260 SP216 (65nm) is for 9.5k. Else, get Palit GTX260 SONIC @ 10.5k. 4870 1GB is for around 9.7k.
Whatever you buy, please get a good SMPS.
Posted again:
dont buy ddr2, ddr3 rams. Get AMD if possible, as it is king unless you can spend ~18k on proc + mobo.
13-11-2009, 09:16 PM
Bond, Desi Bond!
whoa. C2D in this age? that too when core i5 is available for more or less the same price?
14-11-2009, 09:13 AM
Fullbring
 Ooops!!! C2D is old then shud i go 4 AMD.... My budget is only for the whole cabinet....monitor is not needed. only the cabinet system....dat too around 25~30K
ya under 10k so can u tell me which from above GCard is best in performance in games...
pls suggest some good brands(with price) & watts needed...
DDR3 hmmmm....
can u pls tell which is gud proccy under 10k range from any brand(Intel/AMD) which is now rocking....:-P
Posted again:
ok.how much is the price of i5.I hope it as best as C2D series
14-11-2009, 09:15 AM
#19 (permalink)
Attitude matters
Got a call from Microsoft Office, Delhi yesterday. Finally my Windows 7 Ultimate for which I had registered with Tata Croma is ready to be picked up. Price she said something like Rs. Rs.10,553 and not the earlier indicated Rs.11,999. I shall also get a free Reebok watch. (hoping against hope that its a lady's watch - or is there none in Reebok?????)
This time around I have decided to switch over to 64bit. Shall post any hassles as I go along.
14-11-2009, 09:53 AM
#20 (permalink)
Bond, Desi Bond!
hmm. did you check comp@ddict's Latest Prices thread? go to first page and you will find different configurations.
under 10k, I think Zotac GTX260 for 9.5k should be ideal buy.
Corsiar VX series
Tagan TGxxx series
Antec Earthwatts
Cooler Master Real Power
you can look for Tagan 500W 80PLUS certified PSU
AMD Phenom II X4 955 BE is around 9k I think.
core i5 is around 10.5k right now.
14-11-2009, 10:22 AM
#21 (permalink)
Well,for speed better get 64-bit
I can't say anything for 32-bit
14-11-2009, 03:41 PM
#22 (permalink)
Fullbring
@desiibond: Zotac GTX260 for 9.5k??? Is it better than HD4870 ?
AMD Phenom II X4 955 BE is @13.3k > core i-5 @10.5k
so which is superb in performance Phenom or core-i5
14-11-2009, 04:02 PM
#23 (permalink)
^^ dude amd phenom 955be is like 9k... who says its 13.3 k?
14-11-2009, 04:12 PM
#24 (permalink)
Section Moderator
no buddy 64bit is nothing to do with 4GB ram
64bit proc means 64bit registers are used in the processor
64bit OS is OS capable of using full capability of these registers but in 32bit OS only 32bit powwer of proc is exploited
and the amount of ram that can be addressed depends on no of address lines in proci
14-11-2009, 04:48 PM
#25 (permalink)
Bond, Desi Bond!
yep. Phenom II X4 955BE is at 9.1k afaik.
and I always trusted GTX260 more than HD4870. Thanks to PhysX, GTX260 is better VFM.
14-11-2009, 06:57 PM
#26 (permalink)
Chillum Baba
I installed 64 bit and half of my applications wouldn't work. So went back to 32bit.
But recently I read somewhere that Windows 7(pro, ultimate versions) has some XP emulation mode in which other applications can be installed and run!
Yet to try it.
p.s.- someone also suggested me http://www.virtualbox.org/
14-11-2009, 07:25 PM
#27 (permalink)
Attitude matters
^ Yes. Windows 7 Professional, Ultimate and Enterprise editions can be run on Windows XP mode after installing Windows Virtual PC. That is one reason, I am going in for the Ultimate.
See here .
16-11-2009, 10:00 AM
#28 (permalink)
Fullbring
Hello guys,what this person is telling...
Posted again:
 then y u buyed HD4770 then....i mean performance not trust....:-P
16-11-2009, 10:20 AM
#29 (permalink)
Bond, Desi Bond!
at that time, GTX260 was at 12k and HD4770 was 7.2k
and for a 19" display, GTX260 will be overkill.
16-11-2009, 01:59 PM
#30 (permalink)
Crowman
I moved from XP 32bit to Win7 x64 recently. No probs at all. All apps work.
GTX 260 and 4770 are not to be compared really. 4770 is the first 40nm card in the world, nowhere near the raw power of GTX260 or HD4870. But in Crossfire, 4770 beats GTX280 sometimes.
