09-11-2009, 09:52 PM
Excessive happiness
Problem with Dual Boot Win 7 & XP
After installing the Windows 7 after XP, the ntldr and ntdetect.com files of XP seems to be missing. Tried copying it from Windows XP CD using Recovery Console, but still i am unable to enter into XP.
Also installed the EasyBCD and tried all possible solutions, and still problem persists. Tell me guys what should be the closest solution to this....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
09-11-2009, 10:04 PM
Learn & Earn
Re: Problem with Dual Boot Win 7 & XP
well i installed the same a week ago but without any problems
i dont think its a general problem...
10-11-2009, 01:09 AM
Excessive happiness
Well even i installed it previously w/o any problem. This only happens when i re-installed my Win 7 over the existing one(as of some system32 files corrupted). So i guess the update cause some problems to XP's boot file. I tried all the way (even a fixboot cmd in recovery console) still no use.
PS Request
10-11-2009, 01:13 AM
Learn & Earn
when then u could probably re-install them....
яєѕρє¢т ιѕ єνєяутнιηg
10-11-2009, 01:15 AM
Try repair option from windows XP cd to repair winXP then repair win7 using vistabootpro.
10-11-2009, 01:21 AM
Excessive happiness
Well try to re-install XP if there is no sign of solutions for this..
Dude, i've already tried this.
PS Request
10-11-2009, 01:25 AM
Learn & Earn
common bro dont be sad....
its just a matter of 1 hr....
10-11-2009, 01:29 AM
Excessive happiness
installing the OS doesnt take more than 20 mins but installing the reqd s/w seems to be the pain in the a$$. Even forgot to take the image backup, which in this case help to restore to an earlier point w/o any hassle...
PS Request
10-11-2009, 01:34 AM
Learn & Earn
well i meant including the softwares... coz i keep them really organised
10-11-2009, 01:45 AM
Excessive happiness
I am a Marketing manager cum Web Developer. So think of number of softwares i need to install....  Its around 50 of them like Photoshop/Dreamweaver CS3, XAMPP,WebLogic,VS2008 etc.
PS Request
10-11-2009, 02:03 AM
Learn & Earn
ok ok...thats quite biggie...
anyways then why dont u just stick with win 7 didn't like it
10-11-2009, 02:06 AM
Excessive happiness
Nah, Tally 7.1 isn't working with Win 7. One thing that still make me hold of XP...
PS Request
10-11-2009, 10:27 AM
Excessive happiness
^^ Anyone with the solution????? Please guys i need XP badly....
PS Request
10-11-2009, 02:06 PM
not a newbie.....
Boot from the xp cd and go to recovery console then try fixboot. do the same with win7. i think thats gonna help.
10-11-2009, 02:16 PM
Learn & Earn
then u better use a virtualos type of software next time u wanna play with some windows
10-11-2009, 02:27 PM
Always confused
dont worry dude...its easy.
install Vista Boot Pro
Configure the bootloader.
Thats it.
EasyBCD currently is not as functional as it used to in Vista.
Meanwhile, why dont you try Windows Xp Mode RTM in 7 Professional/Ultimate? I really like it. I use Rational Rose old copy in XP mode for activity diagrams.
Vamsi Subhash
visit my blog at www.vamsisubhash.co.cc and taste a bit of IT!
10-11-2009, 03:31 PM
Gracias Senor
Bootloader of XP is corrupt. Insert the XP CD. Goto repair option, provide your admin password so you can get the c:\ Then type the following in order,
fixmbr
bootcfg /scan
bootcfg /rebuild
fixboot
This should fix. If needed, try the same in 7 too.
I do this many a times, once after installing Vista, once after installing Paragon software, which created some bootloader with no options
Try it and let us know.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
10-11-2009, 04:50 PM
Did you copy those files to the root drive of the disk on which Windows XP is installed ?
10-11-2009, 09:32 PM
#19 (permalink)
Excessive happiness
fixmbr
bootcfg /scan
bootcfg /rebuild
fixboot
I have heard that modifying mbr may cause data loss or partitions could get deleted. Is that true? Or just a mighty fake Myth?
Posted again:
Thats it.
Will give it a try and post here......
PS Request
Reason: Automerged Doublepost
10-11-2009, 10:37 PM
#20 (permalink)
Simply a DIGITian
Nope......fixmbr command wont del ur partition. None of ur data will b lossed. Dont worry.
- Read The Forum RULES First.
- Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
- Before Starting A New Thread Read The STICKY THREADS First
- Before Participating In Bazaar Section Read The BAZAAR RULES
11-11-2009, 01:46 PM
#21 (permalink)
Gracias Senor
True, I do this whenever I face boot problem. Fixes it in a jiffy!!
14-11-2009, 03:35 PM
#22 (permalink)
Excessive happiness
fixmbr
bootcfg /scan
bootcfg /rebuild
fixboot
Tried it, but its not working. Coz the whole 25GB(where i installed XP) contains mostly bad sectors. So deleted the partition and leave it un-formatted. Installed 7 64 bit and bye-bye for Dual Boot
PS Request
24-11-2009, 10:57 AM
#23 (permalink)
Gracias Senor
somehw or the other you have solved ur issue. Congrtz!!!!
24-11-2009, 11:06 PM
#24 (permalink)
I once faced the problem, the chkdsk utility was able to solve the problem
30-11-2009, 12:48 PM
#25 (permalink)
I always fail to understand that why there is discussion of Windows Mobile 7 which is not yet released. Windows Mobile 6.5 is released and available in the market and is comparatively doing very well. Market Share is the added feature from which you can get any application, games and widgets. This mobile store is set to fulfill your application hunger.
