Old 08-11-2009, 02:13 PM   #1 (permalink)
Post Connecting Vista Home with XP home
Hi,
I recently bought a Dell lappie which came with Vista Home premum SP1 , i m trying to coonect it with my home compaq PC Xp HOME fully updated... via Ethernet cable
I have set Ip addres 192.168.1.1 for Vista home and 192.168.1.2 for XP home...and subnet mast 255.255.255.0 for both I can ping both machines... even play multiplayer AOE II on them . Obviously can Ping each other..
But i just cannot open using command \\192.168.1 or .2 ... An error occurs... can u ppl suggest some method how to enable this.. So that i can copy files from XP home to Vista Home.
I can see both pc in Network map of Vista
Note : i am using same workgroup : TEST for both pc
plz help or i will tear my hairs off my head ......
navisangha is offline
Old 08-11-2009, 09:02 PM   #2 (permalink)
rohit330's Avatar
Default Re: Connecting Vista Home with XP home
Hi friend,
Please go through this and see it helps.. HERE
Best Regards,
_Rohit
rohit330 is offline
Old 09-11-2009, 12:50 PM   #3 (permalink)
no help ... some more suggestions plz
Old 09-11-2009, 01:32 PM   #4 (permalink)
Have you enabled file sharing and given folders on the pc sharing permission? If so, try entering \\192.168.1.1\share and see if you can access it... Sometimes I find that just entering host name does not give access but if you enter the share name also, access is provided...
Arun
sakumar79 is offline
Vista SP1, XP SP3 and Windows 7 Need to Be on the Lookout for Leopard(s) CadCrazy Technology News 3 28-03-2008 05:17 PM
Vista SP1: Still lagging behind the Linux desktop CadCrazy Technology News 6 11-03-2008 09:45 AM
AutoPatcher for Windows XP SP 2 - August 2006 - Full, Lite & Update rajat22 Software Q&A 7 17-10-2006 10:24 PM
Boot up Windows XP 60 times faster rajat22 Tutorials 8 04-12-2005 09:45 PM
Microsoft VISTA !!! subhu Software Q&A 27 06-09-2005 09:47 PM
- by chris
