Hello friends,
My System takes long time to Boot it shows the POST Screen for about 5 Minutes at that moment system gets Hanged and Nothing Works even the F@ key to go to the BIOS. after 5 minutes it goes to BIOS( If Pressed F2) otherwise Boots XP. I wanted to Format the system but then it is Not Booting from CD I wait till 5 minutes then is again boots XP. After XP is Loaded it works really fine there is o problem after XP loads.
Please help me so that I don't have to wait every time I start PC.
Thanks in Advance....
