Old 04-07-2005, 06:07 PM   #1 (permalink)
Just Do It
Charley's Avatar
Default Help me remove these trojan and virus. Tks
These are the trojans and virus I'm unable to remove. I scanned using KAV and found this, it says will be removed on the next reboot. But it hasnt removed it till now.
I have used Antivir, Avast and it doesnt detect this.
Any other suggestions on removing this.....
KASPERSKY ANTI-VIRUS WEB SCANNER REPORT
Monday, July 04, 2005 17:59:29
Operating System: Microsoft Windows 98 SE
Kaspersky Anti-Virus Web Scanner version: 5.0.67.0
Kaspersky Anti-Virus database last update: 4/07/2005
Kaspersky Anti-Virus database records: 129003
Scan Settings:
Scan using the following antivirus database: standard
Scan Archives: true
Scan Mail Bases: true
Scan Target - Folders:
c:\Windows\
Scan Statistics:
Total number of scanned objects: 5312
Number of viruses found: 2
Number of infected objects: 3
Number of suspicious objects: 0
Duration of the scan process: 3988 sec
Infected Object Name - Virus Name
c:\Windows\SYSTEM\oleadm.dll ----> Infected: Trojan.Win32.Agent.ff
c:\Windows\SYSTEM\WININET.DLL ----> Infected: Virus.Win32.Nsag.a
c:\Windows\SYSTEM\intel32.exe ----> Infected: Trojan.Win32.Agent.ff
Scan process completed.
Charley is offline
Old 04-07-2005, 06:17 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
tds-3 (trojan defense suite) is the oldest & the best in this business.
dowload it from http://tds.diamondcs.com.au/
u will have to manually download their latest database from here
http://tds.diamondcs.com.au/index.php?page=update
if required run the scan in the safe mode.
also run ur anti-virus kav in safe mode or else schedule a boot-time scan of your avast. since the virii do not enter memory at these times, detection and removal is assured.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 04-07-2005, 08:55 PM   #3 (permalink)
Just Do It
Charley's Avatar
i've tried this safe mode thing, it detects the virus. It says will remove on next reboot but doesnt the next time....
Charley is offline
Old 04-07-2005, 10:43 PM   #4 (permalink)
expertno.1's Avatar
well how u got infected severly with these
as anandk suggested then i think ur problem will be solved
but i think ur firewall isn't good enough to protect you from trojans and ur antivirus sucks
i dont think kaspersky is a good choice
expertno.1 is offline
Old 05-07-2005, 11:28 AM   #5 (permalink)
Just Do It
Charley's Avatar
can someone give a suggestion or a soln
Charley is offline
Old 05-07-2005, 03:03 PM   #6 (permalink)
anomit's Avatar
Check out the SOPHOS to find out the solution.
Virus.Win32.Nsag.a
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 05-07-2005, 05:27 PM   #7 (permalink)
anandk's Avatar
didi u use tds-3 ?
anyway, since u know the names of the 3 virii/trojans including their locations, use "delete doctor" to just delete the sticky bxxxxxxx !
download the utility from here and use it :
http://www.softforall.com/Utilities/...or09040223.htm
Microsoft® MVP
anandk is offline
Old 05-07-2005, 07:46 PM   #8 (permalink)
Just Do It
Charley's Avatar
Virus.Win32.Nsag.a
First I have to install Sophos for Win 98SE , can u gimme a link for the download ..
@Anand - Did rrun TDS , nothing detected.
Charley is offline
Old 06-07-2005, 08:03 PM   #9 (permalink)
anandk's Avatar
try delete doctor. it will delete it.
reg link for sophos, better if u send me pvt message.
Microsoft® MVP
anandk is offline
Old 07-07-2005, 11:25 AM   #10 (permalink)
anomit's Avatar
Here is the [url=http://www.sophos.com/products/es/sav/eval/standalone]evaluation[/b] link. Just use it and then uninstall. But too many steps to go through b4 downloading. Very Bad.
anomit is offline
Old 07-07-2005, 11:48 AM   #11 (permalink)
Just Do It
Charley's Avatar
@anomit - i've ordered for a free eval CD, that sounds better, aint it?
I hope that c r a p gets deleted after i scan using it.
Charley is offline
- by chris
