Old 27-10-2009, 02:38 PM   #1 (permalink)
Default Installing problem.
It relates to Windows XP Home Edition. When I try to install Zone alarm free version from a CD",it does not intall itself saying Error Document "index.html" not found. If I try to install Zone Alarm directly from Internet, it does not install at all.How to correct it?
kumarn_2004 is offline
Old 28-10-2009, 06:09 PM   #2 (permalink)
CA50's Avatar
Default Re: Installing problem.
Hi this could be due to virus or spyware check ur pc for virus. Alternatively u can go 4 other softwares similar to zone alarm
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Installing Problem gapchoo009 QnA (read only) 1 25-03-2008 12:48 PM
DirectX 9.0c Installing problem. Help Required !! arnold Software Q&A 1 19-03-2006 08:16 AM
Problem Installing MS-DOS 7.10 anna_don QnA (read only) 3 09-07-2005 04:26 PM
Installing BitDefender problem.. //siddhartha// Open Source 8 14-05-2005 08:56 AM
Problem in installing mplayer in fedora3 neerajvohra Open Source 2 16-02-2005 01:08 AM
- by chris
