Old 23-10-2009, 05:02 PM   #1 (permalink)
rohitshubham's Avatar
Default help needed in checkdisk
hey,
some files of my c:\ drive has been corrupted.(fidbox.dat)
and on every restarts it asks for check disk but it stops at step 2(verifying indexes) at zero percent..
and if a pen drive is inserted in the usb port then my keyboard doesn't work so, i cant even cancel the disk check without removing the pen drive.
and when i try to check disk using chkdsk command it doesn't work it says
"error found . check disk cannot continue in read only mode" and also never goes above zero percent in stage 2....
help me .
i have windows xp with sp3
rohitshubham is offline
Old 23-10-2009, 05:28 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: help needed in checkdisk
a> Why do u keep USB drives plugged in and reboot? If its having problem, remove and reboot. I don't think its an issue.
b>What is the size of ur C drive? chkdsk may take time depending on the size of teh drive and contents of it.
Again, stage 2 generally takes time. Keep it as it is as long as it wants to take. Its better u run chckdsk once full.
c>chckdsk can't operate on C (supposing its where ur OS is) as it needs to unmount any held files which is not possible while booted in OS.
But, it would work perfectly on other drives u have. Try that. U don't (may not) need to reboot to run chckdsk in those drives.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Old 24-10-2009, 06:00 AM   #3 (permalink)
Default Re: help needed in checkdisk
cancel chkdsk on starup
go to windows cmd prompt
type
chkdsk /r
sri535 is offline
Old 24-10-2009, 12:47 PM   #4 (permalink)
but the restart is not in my control.
it automatically reboots
Old 26-10-2009, 01:34 PM   #5 (permalink)
It happened to me once, mine got stuck at scanning files,
one day I decided to keep it going, after 10 minutes are so, it started to scan, the entire scan took around 40+ minutes.
Try doing that.
techie_85 is offline
Old 28-10-2009, 09:13 PM   #6 (permalink)
CA50's Avatar
U can wait for da chkdsk 2 complete. Ur hdd may develope some fault check with other disk utily for bad sector. Chkdsk will hang if bad sectors is detected
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 30-10-2009, 05:12 PM   #7 (permalink)
thanx as my problemhas been solved
left it for superlong time
Old 30-10-2009, 09:59 PM   #8 (permalink)
CA50's Avatar
have fun buddy
| Nokia 2700c |
CA50 is offline
Old 30-10-2009, 11:04 PM   #9 (permalink)
Democracy is a myth
rhitwick's Avatar
Exclamation Re: help needed in checkdisk
I'm curious to know, how long?!
rhitwick is offline
Old 31-10-2009, 05:10 PM   #10 (permalink)
1hrs to 2hrs
Old 31-10-2009, 06:41 PM   #11 (permalink)
CA50's Avatar
thats grt u have patience. this got proved.
| Nokia 2700c |
CA50 is offline
Old 31-10-2009, 09:32 PM   #12 (permalink)
not a newbie.....
papul1993's Avatar
sabar ka phal meetha hota hai
papul1993 is offline
Old 05-11-2009, 05:38 PM   #13 (permalink)
yup
laga ke chai nasta kar liye
- by chris
