Old 30-09-2009, 08:27 AM   #1 (permalink)
Tech addict
surinder's Avatar
Default Dial up modem giving problems
One of my friends using dial up modem from last year and half. But from few days back it can't detect dial tone but dial tone is very clear. Phone calls can be made from phone connected from modem's phone out and if we take of phone receiver then try to connect while dial tone remains it connects but not great deal of data communication.
I uninstalled and re installed its drivers but to no avail and device manger detects modem is working fine. So where could be the problem?
Please help.
surinder is offline
Old 15-10-2009, 01:17 PM   #2 (permalink)
Tech addict
surinder's Avatar
Default Re: Dial up modem giving problems
No solution as yet.
surinder is offline
Old 21-10-2009, 02:41 PM   #3 (permalink)
Always Fresh!
shri's Avatar
Tell your friend to move on...
BE YOURSELF :)
http://everythingoutthere.co.cc
shri is offline
Old 22-10-2009, 06:50 AM   #4 (permalink)
Tech addict
surinder's Avatar
but he is such a idiot I could not impress him enough either for broadband or for just throw the presumably faulty modem and get a newer one.
surinder is offline
Old 24-10-2009, 06:04 AM   #5 (permalink)
run diagnostics
sri535 is offline
Old 29-10-2009, 07:50 AM   #6 (permalink)
CA50's Avatar
Check da phone line joints or leakage is not good
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
- by chris
