| Forum |
#1 (permalink) |
mortal kombat
well from few days i am experiencing these problems. 1.sometimes when i restart the system through windows.it just goes to kinda 'stand by mode'.i mean even if i move the mouse or press any button it does not show any response and remain in that condition only until i restart by pressing the restart button. 2.some games which used to work better earlier now slows down sometimes or even stutter unecessarily sometimes. 3.to open 'my computer' or 'my documents' by double clicking through desktop takes a noticeable amount of time.it takes more time to open. |
#2 (permalink) |
Crowman
Is there free space on your OS drive? Sure there are no viruses on your PC? Use CCleaner and rid your PC of all the muck and report.
Like a post? Use the reputation button.
Abusive, offtopic post? Use the report post button. Read before messaging any moderator for any query: FAQ + answers for new members Read all the sticky threads before asking any type of query. Most basic questions are answered in those. |
#3 (permalink) |
mortal kombat
yeah did almost everything.
the games also shows some strange behaviour.( in between sometimes) i mean if it does not stutter then sometimes it behaves in a 'wavy manner'.i mean it works smooth then it becomes a bit slow (no stutter.like in slow motion for a fraction of a sec) then again to normal.like this it continues. so it gives kinda to and fro motion to the charecter even though it is moving linearly. |
#4 (permalink) |
Crowman
Try uninstalling and updating your gfx drivers and then report on games.
#5 (permalink) |
mortal kombat
checked that also but no improvement.there is no fixed or specific place where it starts.it just starts randomly at anytime.but it is not observed at the starting of any game.it occurs after some time in between.
though it is minor but still it is noticeable. btw i am thinking of installing win7 on my 'e' drive to test .i have currently windows xp sp3. i have never before installed a dual boot system. can you please tell me. 1.if i install win7 on e drive then will the files present on e drive will get deleted. 2.after that if i want to uninstall win7 then what should i do? 3.is it a safe process. |
#6 (permalink) |
mortal kombat
now this is damn irritating and too much.people with similar system as mine can play burnout paradise without any problem.
but in my system this game as i have mentioned previously lags very often even in the low settings. mostly the lags are observed when using a car on bike the lag is less seen. |
#7 (permalink) |
Crowman
Check system temps. kay, now please post your config. Along with OS and Service Pack. 32bit or 64?
To install win 7 is safe AFAIK, but to uninstall you will have to format, so Install in a free drive. I recommend u stick to XP as it worked for me in XP 32 bit with onboard ATI Radeon HD3300 gfx with 640MB shared DDR2 VRAM.
#8 (permalink) |
mortal kombat
winxp sp3 .32 bit people with similar system posted getting 45+ fps at mid high settings.
i tried some forums and some people complained about same issue.even this solution didnt worked for me as i didnt observed anything popping up in my device manager. http://forums.electronicarts.co.uk/b...-paradise.html |
#9 (permalink) |
Crowman
Well Quan Chi, P4 is not really fit to run that game, is it? I had a similar rig, with iball stock 400W psu only difference was Galaxy 6600 256MB PCIe.
All I can suggest to you is that you try the GameBooster. Link: http://www.iobit.com/gamebooster.html ----------------------------------------- Posted again: ----------------------------------------- ADD: In my rig, the game used to crash frequently although it maybe cz my 1GB memory module was faulty. Did you run memtest 86+ on your RAM?
Abusive, offtopic post? Use the report post button. Read before messaging any moderator for any query: FAQ + answers for new members Read all the sticky threads before asking any type of query. Most basic questions are answered in those. Last edited by Krow; 26-09-2009 at 09:55 PM. Reason: Automerged Doublepost |
#10 (permalink) |
mortal kombat
well i dont think that might be the problem search a bit.people even with p4 runs this game at around 60 fps.
this game was claimed to be well optimised. read this review from one of our members. http://www.techenclave.com/gaming/bu...ew-131072.html |
#11 (permalink) |
Crowman
He had a rig with a 3.7GHz P4? Nice OC he did. Try GameBooster and check if there is any difference.
#12 (permalink) |
mortal kombat
lol dude i forgot to mention mine is also oced to 3.35ghz.
btw checked ram with memtest seems to be ok. i think the problem is kind of different please read my post 1 point1 again.this happened today also.i cant find out whats causing this strange problem.defragged the drives also but still no improvement. |
#13 (permalink) |
Crowman
In my experience I have noticed that such tings do happen to XP after some time into the installation. Say, six months after you installed XP the PC becomes slower and progressively so. Try defragging your registry. Also, do the my comp and docs take time to open all the time? Or is it just at startup?
Other queries : How many entries are there during startup? (start>run>msconfig>startup tab) How many processes are running after your rig has booted up fully?
#14 (permalink) | ||
mortal kombat
but the folders present inside them opens normally. Quote:
Logfile of HijackThis v1.99.1 Scan saved at 11:58:09 PM, on 9/23/2009 Platform: Windows XP SP3 (WinNT 5.01.2600) MSIE: Internet Explorer v7.00 (7.00.6000.20627) Running processes: C:\WINDOWS\System32\smss.exe C:\WINDOWS\system32\winlogon.exe C:\WINDOWS\system32\services.exe C:\WINDOWS\system32\lsass.exe C:\WINDOWS\system32\nvsvc32.exe C:\WINDOWS\system32\svchost.exe C:\WINDOWS\System32\svchost.exe C:\WINDOWS\system32\spoolsv.exe C:\WINDOWS\Explorer.EXE C:\Program Files\Analog Devices\Core\smax4pnp.exe C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe C:\Program Files\Common Files\Real\Update_OB\realsched.exe C:\WINDOWS\system32\rundll32.exe C:\WINDOWS\system32\RUNDLL32.EXE C:\WINDOWS\system32\ctfmon.exe C:\WINDOWS\msa.exe C:\DOCUME~1\Admin\LOCALS~1\Temp\b.exe C:\WINDOWS\system32\ctfmon.exe C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\mdm.exe C:\Program Files\Norton AntiVirus\Engine\16.0.0.125\ccSvcHst.exe C:\Program Files\CyberLink\Shared files\RichVideo.exe C:\WINDOWS\system32\wscntfy.exe C:\Program Files\Norton AntiVirus\Engine\16.0.0.125\ccSvcHst.exe C:\Program Files\uTorrent\uTorrent.exe C:\Documents and Settings\Admin\Desktop\HijackThis.exe R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896 R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/ R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157 R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896 R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896 R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157 R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://search.yahoo.com/search?p= R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch = R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll O2 - BHO: XML module - {500BCA15-57A7-4eaf-8143-8C619470B13D} - C:\WINDOWS\system32\msxml71.dll O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll O2 - BHO: Symantec Intrusion Prevention - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files\Norton AntiVirus\Engine\16.0.0.125\IPSBHO.DLL O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\PROGRA~1\MICROS~2\Office12\GRA8E1~1.DLL O2 - BHO: SingleInstance Class - {FDAD4DA1-61A2-4FD8-9C17-86F7AC245081} - C:\Program Files\Yahoo!\Companion\Installs\cpn\YTSingleInstan ce.dll O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll O3 - Toolbar: DAEMON Tools Toolbar - {32099AAC-C132-4136-9E9A-4E364A424E17} - C:\Program Files\DAEMON Tools Toolbar\DTToolbar.dll O4 - HKLM\..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\Core\smax4pnp.exe O4 - HKLM\..\Run: [VistaDrive] C:\WINDOWS\VistaDrive.exe O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Nero\Lib\NeroCheck.exe O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe" O4 - HKLM\..\Run: [GrooveMonitor] "C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe" O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe" O4 - HKLM\..\Run: [LanguageShortcut] "C:\Program Files\CyberLink\PowerDVD\Language\Language.exe" O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime O4 - HKLM\..\Run: [USB Gamepad] C:\WINDOWS\USB Vibration\dr100&110\USB Gamepad.exe -boot O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot O4 - HKLM\..\Run: [UnlockerAssistant] "C:\Program Files\Unlocker\UnlockerAssistant.exe" O4 - HKLM\..\Run: [UpdatePDRShortCut] "C:\Program Files\CyberLink\PowerDirector\MUITransfer\MUIStart Menu.exe" "C:\Program Files\CyberLink\PowerDirector" UpdateWithCreateOnce "Software\CyberLink\PowerDirector\7.0" O4 - HKLM\..\Run: [BluetoothAuthenticationAgent] rundll32.exe bthprops.cpl,,BluetoothAuthenticationAgent O4 - HKLM\..\Run: [nwiz] C:\Program Files\NVIDIA Corporation\nView\nwiz.exe /install O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup O4 - HKCU\..\Run: [DAEMON Tools Lite] "C:\Program Files\DAEMON Tools Lite\daemon.exe" -autorun O4 - HKCU\..\Run: [PopRock] C:\DOCUME~1\Admin\LOCALS~1\Temp\b.exe O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe O4 - Startup: Adobe Gamma.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe O4 - Global Startup: Shortcut to RocketDock.lnk = C:\Program Files\RocketDock\RocketDock.exe O4 - Global Startup: Shortcut to sidebar.lnk = C:\Program Files\Windows Sidebar\sidebar.exe O8 - Extra context menu item: &Highlight - C:\WINDOWS\WEB\highlight.htm O8 - Extra context menu item: &Links List - C:\WINDOWS\WEB\urllist.htm O8 - Extra context menu item: &Web Search - C:\WINDOWS\WEB\selsearch.htm O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office12\EXCEL.EXE/3000 O8 - Extra context menu item: I&mages List - C:\WINDOWS\Web\imglist.htm O8 - Extra context menu item: Open Frame in &New Window - C:\WINDOWS\WEB\frm2new.htm O8 - Extra context menu item: Zoom &In - C:\WINDOWS\WEB\zoomin.htm O8 - Extra context menu item: Zoom O&ut - C:\WINDOWS\WEB\zoomout.htm O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\Office12\REFIEBAR.DLL O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing) O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing) O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe O11 - Options group: [INTERNATIONAL] International* O11 - Options group: [TABS] Tabbed Browsing O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/microsoftup ... 0188616578 O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftup ... 0188440531 O16 - DPF: {D1E7CBDA-E60E-4970-A01C-37301EF7BF98} (Futuremark SystemInfo) - http://www.yougamers.com/systeminfo/FMSI.cab O17 - HKLM\System\CCS\Services\Tcpip\..\{FF7088AA-EDD6-4888-8F9E-D3D1661C4DB1}: NameServer = 121.241.40.26 111.125.192.11 O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\PROGRA~1\MICROS~2\Office12\GR99D3~1.DLL O18 - Protocol: ms-help - {314111C7-A502-11D2-BBCA-00C04F8EC294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll O18 - Filter hijack: text/xml - {807563E5-5146-11D5-A672-00B0D022E945} - C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE12\MSOXMLMF.DL L O20 - Winlogon Notify: dimsntfy - %SystemRoot%\System32\dimsntfy.dll (file missing) O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\wpdshserviceobj.dll O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Nero\Lib\NMIndexingService.exe O23 - Service: Norton AntiVirus - Unknown owner - C:\Program Files\Norton AntiVirus\Engine\16.0.0.125\ccSvcHst.exe" /s "Norton AntiVirus" /m "C:\Program Files\Norton AntiVirus\Engine\16.0.0.125\diMaster.dll" /prefetch:1 (file missing) O23 - Service: NVIDIA Display Driver Service (nvsvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared files\RichVideo.exe O23 - Service: TuneUp Drive Defrag Service (TuneUp.Defrag) - TuneUp Software GmbH - C:\WINDOWS\System32\TuneUpDefragService.exe amongst them i have removed msa.exe and b.exe. |
#15 (permalink) |
Crowman
From startup remove:
richvideo.exe and all other power director related processes nerocheck.exe realsched.exe reader_sl.exe groovemonitor.exe ctfmon.exe For disabling ctfmon, u can right click on EN button next to system tray and in settings disable it. Use tuneup to defrag your registry. Uninstall: Yahoo! Toolbar Daemon Tools Toolbar Cyberlink Power Director (if you dont need it) Real Player (you may use VLC only instead) Also, I recommend you uninstall MS Office 2007 and use Office 2003 or even better OpenOffice.org 3.1. Do you use Word for heavy purposes? Do u need all other office apps like powerpoint and excel? Do you make charts in Word? If no for all three, you can install AbiWord, which is a 5mb setup and is a simple and solid word processor.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
