Old 20-09-2009, 11:52 PM   #1 (permalink)
The Last Puff
Artemis's Avatar
Default Audio-Video Driver Problems!!!!
I have a Biostar P4TGV-R v8.1 Mobo
recently after reformatting my HDD, i installed new drivers and everything, even after installing them,
the device manager shows problems (yellow Question marks) on the Video Controller(VGA Compatible)
and the C-Media CI9761_512_WIN9XMENT42KXP
there are flickers on the screen and the movies have a low frame rate, u just can see the refreshing frames, also there is no audio, though there are the usual beeps from the cabinet for the errors..
any help??
Music is the opiate of life and I’m stoned all the time.
MacBook Pro 13”
Aural Nirvana : Audio Technica CK10:-D | Panasonic RP-HJE900 | Alessandro MS-1
Last.fm
Artemis is offline
Old 21-09-2009, 11:01 PM   #2 (permalink)
The Last Puff
Artemis's Avatar
Default Re: Audio-Video Driver Problems!!!!
For the audio deviceIn the device properties it states that the device cannot start -- error code 10
my audio device is C Media AC97
MacBook Pro 13”
Last.fm
Artemis is offline
Old 23-09-2009, 12:43 PM   #3 (permalink)
The Last Puff
Artemis's Avatar
The Video issue is solved, but cant seem to find a solution to the audio device not working, isnt there anybody who could help?
MacBook Pro 13”
Last.fm
Artemis is offline
- by Anorion
- by ax3
