Old 16-09-2009, 11:57 PM   #1 (permalink)
rajwansh2003's Avatar
Default Vista ultimate Space problem
I am having windows Vista ultimate one folder at c:windows/winsxs
"winsix" contain 12GB.
Can i delete this folder without problem to OS. or how to make space....
PLZ help
Anupam
rajwansh2003 is offline
Old 17-09-2009, 06:18 PM   #2 (permalink)
Default Re: Vista ultimate Space problem
Hi Raj,
The WinSXS folder is very important folder in Vista. This is folder has the Side by Side configuration of the operating system files. If you delete the folder, the operating system will not boot at all or it will not work.
If you have any problem with any DLL files under "C:\Windows\System32\", you can very well copy and replace the problem file from the "WinSXS" folder.
I hope you can understand the importance.
Regards,
Mathan Raj A
v-6mata is offline
- by chris
