Old 16-09-2009, 12:14 PM   #1 (permalink)
Smile spyware problem
Hi Guys,
Having Windows XP Home edition(SP3) COMODO INTERNET SECURITY on my system. Having got spyware,addware problem. What is the best free spy-ware removal software(no online scanning options needed)?
kumarn_2004 is offline
Old 16-09-2009, 09:43 PM   #2 (permalink)
Amir.php's Avatar
Default Re: spyware problem
free: Spybote search and destroy. paid: avg antispyware, adaware, spyware doctor.....but i want to suggest you to download and run 'Combo fix'. it surely solve your problem. just google it.
Amir.php is offline
Old 18-09-2009, 08:32 PM   #3 (permalink)
You can use X59Com Backdoor Eliminator.It is the most effective.Its free but then again you have to find it somewhere.its rarely found on the world wide web.
Matt Parker is offline
Old 18-09-2009, 09:00 PM   #4 (permalink)
S.I.P.
JojoTheDragon's Avatar
I suggest download some good reputated av like KIS or Bit defender trial and kill the threat and then install a good free fire wall and av
JojoTheDragon is offline
Old 19-09-2009, 01:44 PM   #5 (permalink)
swatkat's Avatar
Originally Posted by kumarn_2004 View Post
Hi Guys,
Check out Malwarebytes Anti-Malwre. It is free and has good detection/removal capablities.
http://www.malwarebytes.org/mbam.php
http://swatrant.blogspot.com/
swatkat is offline
