Old 01-09-2009, 03:41 PM   #1 (permalink)
Default Anything for better sound?
Hi Guys,
I have got Windows XP Home Edition(SP2). My headphone have not got volume control attached to it. So, the only way to
increase and decrease volume control is with the help of my PC. My headphone cannot give me sufficient volume though the adjustment on my PC is high level. Is there any way to increase the volume level by changing the settings anymore on my PC or by adding any software?
kumarn_2004 is offline
Old 01-09-2009, 06:55 PM   #2 (permalink)
Default Re: Anything for better sound?
Get another pair of headfones. Thats might be the highest volume for your headfones. Which one are you using ?
and for better quality you can add a new sound card
cyberxtremer is offline
Old 03-09-2009, 10:01 PM   #3 (permalink)
Working on my Thoughts
suzy's Avatar
Smile Re: Anything for better sound?
Try DFX Audio Enhancer. It gives you better sound & it boosts audio to an extent. You may give it a try.
suzy is offline
Old 04-09-2009, 12:36 PM   #4 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Originally Posted by kumarn_2004 View Post
Hi Guys,
you want to listen to songs with high volume there are two ways afaik.
1. If If you use Windows Media Plater to play...you can turn on the TruBass and Wow effect. They will considerabl give better sound.
2. You will have to use Media Player Classic. Go to View >> Audio Switcher and then slide the boost bar towards the right. There will be a bit distortion in the sound but you will get loud sound.
Alternatively you can buy earplugs which costs nearly Rs 150 -Rs 200 for listening which will promisingly give you loud and better sounds than headphones of the same range.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 05-09-2009, 11:54 AM   #5 (permalink)
Welbeck fan :D
XTerminator's Avatar
if u listen to music frequently,getting a good headphone set would be a wise choice..also the media player classic trick is good,also check on the normalise option.
XTerminator is offline
- by chris
