Originally Posted by solomon_paulraj
the best is musicmatch jukebox.. i have almost converted 200 of my cassettee using it (for almost 6 months)..
the software suppresses the hiss and humm... and i recommend it sincerely..
Even I used Jukebox for the same purpose.
But, let me tell you its a very cumbersome task.
To get each song as a diff file either you need to stop recording as soon as the songs ends or you can record whole sides as a file then split it.
I converted two cassettes then stopped due to laziness
But, yeah, jukebox does the job very good.
