Old 04-08-2009, 08:19 PM   #1 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
Default Monitor and vga problem.
Hi,
I'm using a P4 based PC. It has a Zebronics 845 motherboard. The motherboard has intel graphics extreme. I changed the screen colors to high and from then the monitor goes off when its boots into xp. The refresh rate of the high color, i selected is more than supported by my monitor. Now i can't revert back to normal colors.. In safe-mode i can only disable the vga drivers. Re-installing vga drivers ain't helping either. Anyone know a way to revert back to default?
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline
Old 04-08-2009, 08:41 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: Monitor and vga problem.
Me too faced the same prblm once....!!
Boot into safe mode...go to run>type msconfig>press enter.
From the startup's tab disable loading of VGA driver.
After tat boot into normal mode and go to control panel. U'll find Intels VGA thr. Open it and revert it...!!
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
Old 04-08-2009, 08:58 PM   #3 (permalink)
It doesn't matter!
Its similar to what I tried.. The intel vga in control panel wouldn't open in both safe mode and normal. So i can't revert back.
Old 04-08-2009, 10:52 PM   #4 (permalink)
Can't you uninstall (not just disable) your Intel display drivers from Add/Remove Programs in Safe Mode?
I work with Intel systems only very occasionally, so I can't say exactly how you should go about it. But I'd expect that it wouldn't really be that much different from AMD systems.
If you can uninstall the driver in Safe Mode, you can then boot into normal mode and reinstall the display driver.
pimpom is offline
Old 04-08-2009, 11:14 PM   #5 (permalink)
Simply a DIGITian
^^Tats rite
Old 05-08-2009, 05:04 AM   #6 (permalink)
Check your computer if you have toshiba cd speed tester installed. VGA have several problems with toscdspd.exe too.
<<<<<<<<<<<<<<<SaXaM>>>>>>>>>>>>
Saksham ghimire is offline
Old 05-08-2009, 08:00 AM   #7 (permalink)
It's better to boot your computer with Bootable WIN xp CD and at the set up screen just press F3 to repair the existing OS.
This may solve the problem!!
The same problem I faced in the computer institute when one of my student played with the display settings.
Rose
rose tamang is offline
Old 05-08-2009, 08:08 AM   #8 (permalink)
It doesn't matter!
As I already mentioned uninstalling and re-installing didn't help.. I wanted to know if there anyone knew where Intel stored the values or someway by which I could bring it back to default..
No toshiba isn't there or my PC.
Repairing isn't gonna work i guess formatting is only option..
Thanks for the help everyone..
Old 05-08-2009, 10:35 AM   #9 (permalink)
As I say just try once to repair your OS!!
Other wise as you wish!!
- by chris
